problems with a 2600 console
malfunctions
15 replies to this topic
#1 scottydu81 OFFLINE
scottydu81
    Combat Commando
  • 6 posts
Posted Thu Jan 19, 2012 6:20 PM
I recently aquired a 2600 console (the all black, four switch model) and it seems to need to actually "warm up" before it works consistently. i have to put cartidge after cartridge in, and all that happens is that the game displays for a few seconds, then the screem either goes to black, or a whole scramble of colors. i keep switching out cartridges until it magically stops doing that.
anyone else experience this?
#2 ACrystal2011 OFFLINE
ACrystal2011
    Moonsweeper
  • 360 posts
Posted Thu Jan 19, 2012 6:50 PM
Did you try cleaning the cartridge port?
#3 scottydu81 OFFLINE
scottydu81
    Combat Commando
  • 6 posts
Posted Thu Jan 19, 2012 7:16 PM
not really. but i didnt think that was an issue because it eventually works just fine. just seems like it needs to warm up first.
by the way, whats the best advice for cleaning the cartridge port?
#4 ACrystal2011 OFFLINE
ACrystal2011
    Moonsweeper
  • 360 posts
Posted Thu Jan 19, 2012 7:23 PM
Check the forums im sure i saw a post about it somewhere i have never done it tho. I just figure maybe the carts not getting a good connection
#5 scottydu81 OFFLINE
scottydu81
    Combat Commando
  • 6 posts
Posted Thu Jan 19, 2012 7:27 PM
i tried all my NES tricks, but i guess its not the same beast... i dunno, i saw an atari 2600 disassembly video on youtube and it looks easy. maybe ill just crack it open and have a look.
#6 SlowCoder OFFLINE
SlowCoder
  • 2,913 posts
Posted Fri Jan 20, 2012 11:15 AM
My typical slot cleaning methods is to take a game and wet the connectors with alcohol. Insert the cart multiple times. If that's not sufficient, cut some 1/8 cardboard and douse it with alcohol and gently insert in slot. If THAT doesn't work, fine grit sandpaper. Bit the sandpaper is last ditch effort for me, as while it might work temporarily I think over long term it does more damage than good.
BUT ... based on your description it sounds like you've got a power related problem. One of your chips might be bad. Or you may need to replace the green "chiclet" capacitor near the power switch inside.
#7 Rex Dart ONLINE
Rex Dart
  • 3,753 posts
  • NO CASH VALUE
Posted Fri Jan 20, 2012 11:19 AM
Any chance it's the voltage regulator?
#8 scottydu81 OFFLINE
scottydu81
    Combat Commando
  • 6 posts
Posted Fri Jan 20, 2012 6:12 PM
it works after a while. about a few minutes of switching cartridges, it works just fine for as long as i play. i havent taken it apart yet, though i will soon.
#9 Sean39 OFFLINE
Sean39
    Moonsweeper
  • 280 posts
  • Atari 800 systems
Posted Fri Jan 20, 2012 8:47 PM
Hi
I have repaired many of the Atari 2600 units. it sounds like you have a cold or broken solder connection on the Cartridge port. It sounds like sometimes you
are making connection to the main board and other times you are not. I have Several Atari 2600 systems from the Actual year 1977 and cleaning the port
will help. I have notice that Atari are really good about the ports not getting dirty,but they can break solder connections from the force placed on insering
the connector.
Hope this helps out.
Sean
#10 scottydu81 OFFLINE
scottydu81
    Combat Commando
  • 6 posts
Posted Sat Jan 21, 2012 4:53 PM
i cracked open my console. it has been some years since i worked with any circuit cards (and even then, they were made well after 1977), but i dont see anything that looks burnt out even though its hard to tell one way or the other.
it still works, i guess ill just give it a few minutes warm up when i want to play. i found out i can just kick the power switch on, go get something to eat, come back and play all night.
#11 ACrystal2011 OFFLINE
ACrystal2011
    Moonsweeper
  • 360 posts
Posted Sat Jan 21, 2012 5:33 PM
Um maybe it doesnt like to work cuz you kick it :lol:
#12 scottydu81 OFFLINE
scottydu81
    Combat Commando
  • 6 posts
Posted Sat Jan 21, 2012 7:35 PM
ill kick it if i want to, fool! i do whut i want!
#13 ACrystal2011 OFFLINE
ACrystal2011
    Moonsweeper
  • 360 posts
Posted Sat Jan 21, 2012 9:14 PM
LOL :)
#14 lushgirl_80 OFFLINE
lushgirl_80
  • 1,193 posts
  • currently playing Demon Attack on Atari 2600
Posted Sun Jan 22, 2012 5:53 AM
That also happened the last time I hooked up my Vader. That's why I always play my 4-switch Woodgrain the most.
I need test it again because it did work great for awhile. I remember the colours were much sharper on the Vader 2600.
#15 Trinity OFFLINE
Trinity
    Dragonstomper
  • 664 posts
Posted Mon Jan 23, 2012 1:04 AM
I'd check the 7805 voltage regulator for a good 5 volt output. ;)
#16 31336haxx0r OFFLINE
31336haxx0r
    Moonsweeper
  • 384 posts
Posted Mon Jan 23, 2012 2:45 AM
Definitely check it and also look out for failing capacitors (dried up, bulged out, etc.).
