0
800XL stuck asterisk key
4 replies to this topic
#1 rpc9943 OFFLINE
rpc9943
    Space Invader
  • 28 posts
Posted Mon Jan 23, 2012 8:46 PM
Hey what should I do, stuck asterisk key, it boots to my sdrive but stays there trying to arrow down infinitely. Can I fix this or do I have to get my old 130XE from my parents now?
#2 bbking67 OFFLINE
bbking67
    Star Raider
  • 98 posts
Posted Mon Jan 23, 2012 9:38 PM
if you unplug the keyboard what happens?
#3 rpc9943 OFFLINE
rpc9943
    Space Invader
  • 28 posts
Posted Tue Jan 24, 2012 7:02 AM
Well, I'm not sure how to do that.
#4 sloopy ONLINE
sloopy
  • 2,258 posts
  • lookin for bits, i like bits...
Posted Tue Jan 24, 2012 7:16 AM
Turn it over, remove the screws from the bottom. Turn it back over, and then lift the top, lift the right side 1/2 inch, and the left side 4-5 inches. Inside you will see the kb connected to the mainboard by a ribbon cable, carefully with two hands lift up on it...
Connect power/video connections, and turn it on... if the key is still stuck, then bad 4051 or pokey. if it isnt stuck then problem in the key itself...
sloopy.
#5 rpc9943 OFFLINE
rpc9943
    Space Invader
  • 28 posts
Posted Sun Apr 15, 2012 6:52 AM
Okay, well it turned out that now it's just the break key that works, and everything operates just fine. This must be the keyboard. I took the atari apart and removed the ribbon, and pencil erased it. There was the same outcome. I also got two atari 130XE's which both don't load properly, not sure what the hell to do with those! I think we have an atari 600 somewhere at my parents, maybe I'll just get that and hope for the best.
