0
Picture Quality
1 reply to this topic
#1 cobras OFFLINE
cobras
    Combat Commando
  • 3 posts
Posted Thu Jan 26, 2012 10:26 AM
Well I just dusted my 2600 off and plugged it into my TV and it works. I do have some white fuzzy horizontal lines that run up the screen. Is there a fix for this? I hooked it up with the switch box connected to the little transformer that pushes onto the coax connection. I couldn't find one of those silver RCA to coax adapters locally. Thanks.
#2 keilbaca OFFLINE
keilbaca
    Salame!
  • 7,185 posts
  • Code Monkey like Tab and Mt. Dew
Posted Thu Jan 26, 2012 11:24 AM
There are a couple ways you can increase picture quality.
First off is getting the adapter you're talking about. AtariAge sells it here in the Store, and it works very well.
Another is to buy a replacement cable for the 2600. Its a shortened RCA jack that plugs into the Atari itself, and you can't just use any composite cable off of the shelf, you need a super thick one to block out interference.
The last way is to modify it for composite/s-video. If you want the best picture from your Atari, and you have basic soldering skills, I'd look into that. The S-Video picture is unmatched to any RF signal that you can possibly try to clean up.
Welcome to AtariAge!
