Moon Patrol and Jungle Hunt file version sound issues
10 replies to this topic
#1 Gunstar OFFLINE
Gunstar
    Gunstar
  • 6,551 posts
Posted Fri Jan 27, 2012 7:07 PM
Are there any file versions of these games that don't have the sound issues; music screwed up on Moon Patrol and sound-turn-static on Jungle Hunt boulder scene?
As I recall, this isn't and 800 OS only problem since the cartridges used to work fine on my 130XE when I had them.
#2 Rybags OFFLINE
Rybags
  • 10,314 posts
Posted Fri Jan 27, 2012 7:13 PM
With Jungle Hunt, the bad version seems to have some zeros where the sound data should be which messes up the volcano level.
Moon Patrol I think there's a good one around. Problem with that one I think is that SKCTL isn't initialized properly which messes up the sound.
I've got a good Moon Patrol but it's on real floppy and all that stuff's packed away.
#3 kenfused OFFLINE
kenfused
  • 1,192 posts
Posted Fri Jan 27, 2012 7:30 PM
See post 2 of this thread for Moon Patrol, Mario Brothers and Gremlins with fixed sound
http://www.atariage...._1#entry2213980
#4 AtariLeaf OFFLINE
AtariLeaf
  • 6,287 posts
Posted Fri Jan 27, 2012 8:05 PM
Are these carts that have the bad sound? I played Jungle Hunt and Moon Patrol on my 800XL just to see and both sound fine. I found a youtube video of Jungle Hunt with the hissing noise in the boulder scene but my cart doesn't have this issue. Is it bad carts? Combination of certain hardware that causes this?
#5 kenfused OFFLINE
kenfused
  • 1,192 posts
Posted Fri Jan 27, 2012 8:14 PM
The three I posted just have code to reset POKEY before running the game. I think the originals only produce bad sound on an XL and XE and probably wont produce bad sound if loaded from a non-SIO device.
#6 Gunstar OFFLINE
Gunstar
    Gunstar
  • 6,551 posts
Posted Fri Jan 27, 2012 8:52 PM
No, the cartridges are all fine, this problem occurs with some cartridge rom images that have been turned into files loaded through DOS.
#7 Marius1976 ONLINE
Marius1976
  • 1,701 posts
Posted Sat Jan 28, 2012 5:21 AM
IIRC the moon patrol with the wrong sound is OS B version, but I might remember this wrong.
did you already found a good one?
#8 Gunstar OFFLINE
Gunstar
    Gunstar
  • 6,551 posts
Posted Sat Jan 28, 2012 11:44 AM
Yeah, got a good moon patrol file now. Still need Jungle Hunt.
#9 Gunstar OFFLINE
Gunstar
    Gunstar
  • 6,551 posts
Posted Sat Jan 28, 2012 11:48 AM
The last time I played moon patrol was a file version on a 130XE and it had the sound issue, but, I had the actual cartridge at one time and it played fine on that same 130XE. The file version I have had has the same sound issue on my 1200XL with the XL/XE OS chip. I don't think I tried it on the 1200XL OS before I upgraded.
In any case, I have another 1200XL with the 32-in-1 Warp OS and once I get it fixed I'll try out these game files with the corrupt sound issues on all the OS's to see if it's OS issues or just rom image to file conversion issues. I'm going to buy the original cartridge versions of MP and JH as soon as I can anyway.
Edited by Gunstar, Sat Jan 28, 2012 11:54 AM.
#10 slampam OFFLINE
slampam
    Moonsweeper
  • 308 posts
Posted Fri Feb 3, 2012 1:03 PM
Change one digit in this jungle hunt xex string and it'll mostly fix the boulder sound.
31F0: B3 4B B3 6A B3 89 B3 E0 (BF) 9D B3 C5 B3 31 B2 53
31F0: B3 4B B3 6A B3 89 B3 E0 (BE) 9D B3 C5 B3 31 B2 53
#11 Fres OFFLINE
Fres
    Dragonstomper
  • 507 posts
Posted Fri Feb 3, 2012 4:18 PM
Very cool. That does make it a lot better. Still not 100%, but much better than that white noise. I messed around with the file a bit myself, but I was not able to make any improvements. Nice work, slampam!
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
