1 sector: changing content?
6 replies to this topic
#1 Marius1976 OFFLINE
Marius1976
  • 1,701 posts
Posted Fri Feb 3, 2012 9:38 AM
How is this possible:
I have a floppy disk here. It is a copy protected floppy.
It is medium density, and sector $03DE (990) is filled with #$FF. Well... that is the FIRST time you read that sector.
When you RE-READ the sector it reads all #$00!
When you RE-READ it one more time the sector reads sometimes #$FF and sometimes #$FF.
(I mean the sector is filled with 128x the same value; all are #$00 or all are #$FF)
My questions are:
1) Is it possible to reproduce this behavior on a .ATR image?
2) How in the world does this work? Is there something funny going on here?
3) How can I create such a disk myself?
Thanks
M.
#2 Rybags OFFLINE
Rybags
  • 10,314 posts
Posted Fri Feb 3, 2012 9:55 AM
The old "duplicate sector" trick.
Fairly simple - put 2 or more sectors with the same ID in the header, the drive will pick up one or the other depending on what sector was accessed previously.
Such schemes would need a Happy board or similar. ATR doesn't support it, I'd say the protected image formats might.
#3 Marius1976 OFFLINE
Marius1976
  • 1,701 posts
Posted Fri Feb 3, 2012 10:08 AM
Ehm... I don't understand completely yet. Where is this header and what is the ID of a sector? Isn't this simply hard-coded in the firmware of the drive?
When I want to access sector $03DE and I instruct my drive to read that sector, where does it get that "ID"?
And even when I give 5 times the SAME instruction:
read $03de
read $03de
read $03de
read $03de
read $03de
the results are not all the 5 times the same.
Thanks for your assistance!
#4 Marius1976 OFFLINE
Marius1976
  • 1,701 posts
Posted Fri Feb 3, 2012 10:20 AM
ah... I found this:
http://www.scribd.co...tion-Techniques
That describes what you suggested. Hmmm. Interesting
#5 Rybags OFFLINE
Rybags
  • 10,314 posts
Posted Fri Feb 3, 2012 10:37 AM
ID as in part of the header data the disk controller needs to find sectors on a track.
Hardcoded ? Kind of. A factory drive will create a cookie-cutter type of layout where each track's layout of sectors is consistent and can't be altered by the user.
A modded drive can let you do fancy stuff like duplicate sector IDs, missing sectors, CRC errors etc etc.
I forget which book, might be one of Sam's computer facts, but the track layout is documented. For each 128 byte sector, there's actually a fair bit more data like sync marks, headers and the like. Datasheets for the popular disk controller chips usually have some description too.
#6 Mathy ONLINE
Mathy
  • 1,167 posts
Posted Fri Feb 3, 2012 4:20 PM
Hello Marius
You should also try to find "Advanced Atari Protection Techniques". It's the second book of the (two part?) series. (BTW I bought these books from Alpha Systems even before I had a disk drive. And NO that are NOT for sale.)
Your "changing sector" could also be a fuzzy sector. A duplicate sector is like two identical twins that take advantage of the fact that you don't know that they are not one but two individuals. But a fuzzy sector is a sector that's partly unformatted. But in such a way, that the drives thinks, it's a normal sector. (BTW I had to look this up, the info indeed is in AAPT (the second book) and not in ASPT (which is mentioned above).)
Mathy
#7 Stephen OFFLINE
Stephen
  • 3,250 posts
  • A8 Gear Head
Posted Fri Feb 3, 2012 5:45 PM
View PostMathy, on Fri Feb 3, 2012 4:20 PM, said:
Hello Marius
Mathy
Those are great books. I met the author at a local computer show, and I had him sign both of mine. He was incredibly shocked to see them on display.
