ATARI Microsoft Basic II Cartridge
51 replies to this topic
#1 Sean39 OFFLINE
Sean39
    Moonsweeper
  • 280 posts
  • Atari 800 systems
Posted Sat Feb 4, 2012 10:06 PM
Hi does Anyone know anything about this cartridge.
Does it take any special Disk with it or another cartridge for the 800 computer?
I have always known microsoft basic to be a very large program that use to have to be loaded in by disk on IBM computers.
Has anyone ever use this program before???
thanks Sean
Posted Image
Posted Image
Edited by Sean39, Sat Feb 4, 2012 10:06 PM.
#2 Bryan OFFLINE
Bryan
  • 7,626 posts
  • Cruise Elroy = 4DB7
Posted Sat Feb 4, 2012 10:24 PM
I've never seen anything done with MS BASIC on the A8. What's the point of developing for an expensive BASIC when there's a pretty good free one? I bet it was mainly used by people who needed to convert a program from another machine running MS BASIC.
#3 Stephen OFFLINE
Stephen
  • 3,250 posts
  • A8 Gear Head
Posted Sat Feb 4, 2012 10:27 PM
I have a copy, but have never used it other than seeing if it booted up. If I'm using BASIC, it's Turbo BASIC XL although I might give BASIC XE a try sometime soon.
#4 Sean39 OFFLINE
Sean39
    Moonsweeper
  • 280 posts
  • Atari 800 systems
Posted Sat Feb 4, 2012 10:50 PM
Hi does turbo Xl basic come on Cartridge or disk??
Also what is XE basic on? Is it a cartridge or disk?
I have been trying to get a copy of XE Basic for my 130XE machine.
Thanks
Sean
#5 Stephen OFFLINE
Stephen
  • 3,250 posts
  • A8 Gear Head
Posted Sat Feb 4, 2012 10:58 PM
TBXL is disk, and I currently run BASIC XE on one of Steve Tucker's 1Mb flash carts.
#6 kheffington OFFLINE
kheffington
  • 1,368 posts
Posted Sat Feb 4, 2012 11:01 PM
It is a combination cartridge disk. You need the disk as an extension to get all of the functions. It is also a memory pig and uses about 32k I think. There are also disk only versions of it.
It is not compatible with Atari basic programs.
I think the disk only version is Microsoft Basic I and the Cart plus disk are Microsoft Basic II.
Edited by kheffington, Sat Feb 4, 2012 11:03 PM.
#7 Sean39 OFFLINE
Sean39
    Moonsweeper
  • 280 posts
  • Atari 800 systems
Posted Sat Feb 4, 2012 11:11 PM
Thanks
I really need a copy of XE basic. I have some programs that say they will only run with using XE basic,so I was hoping to get a copy of it
Thanks
Sean
#8 kheffington OFFLINE
kheffington
  • 1,368 posts
Posted Sat Feb 4, 2012 11:15 PM
I have a copy of the manual at the link below for Microsoft Basic in PDF format. It is around 10MB. Better to right click the link and download it.
http://ravenlist.com...ari/msbasic.pdf
#9 MrFish OFFLINE
MrFish
  • 1,309 posts
  • Schindleria Praematurus
Posted Sat Feb 4, 2012 11:56 PM
Just get an Atarimax FlashCart and burn a copy of BASIC XE onto it.
#10 Rybags OFFLINE
Rybags
  • 10,314 posts
Posted Sun Feb 5, 2012 12:03 AM
Not quite that simple. It's an OSS banked cart. But I beileve that patched images have been made that can be flashed to 128K Atarimax carts.
#11 MrFish OFFLINE
MrFish
  • 1,309 posts
Posted Sun Feb 5, 2012 12:50 AM
That's what I meant. There is already an image on Atarimax's site: BASIC XE for 1mbit cart
#12 Larry OFFLINE
Larry
  • 1,731 posts
Posted Sun Feb 5, 2012 6:56 AM
MSB cart requires an extension disk for several commands and functions.
Basic XE is bank-switching cart comes with an extension disk that includes many added functions.
Basic XL is a bank-switching cart that has an optional "toolkit" with extensions, examples and runtime. (There was also a different, smaller runtime that was commercially available.)
@Sean39: not trying to be picky, but you keep writing about "XE basic." Do you mean "BASIC XE" or are you referring to something else -- what?
The flash image of BASIC XL works perfectly. The flash image of BASIC XE is fine until you run the extensions. Then "it has issues."
-Larry
#13 high voltage OFFLINE
high voltage
  • 1,578 posts
  • Location:America, Asia, Europe, Aus, Antartica, Africa, Outer Space
Posted Sun Feb 5, 2012 10:29 AM
thanks Sean
Posted Image
Posted Image
Microsoft made Basic for many computers not just IBM.
#14 Mirage OFFLINE
Mirage
  • 5,853 posts
  • Have a problem? Hire the Envious Snakes!
Posted Sun Feb 5, 2012 12:28 PM
Yeah, I have one of the Microsoft BASIC II carts. Never used it, never had any reason to.
#15 Gunstar ONLINE
Gunstar
    Gunstar
  • 6,551 posts
Posted Sun Feb 5, 2012 12:43 PM
At one time, way back in the 80's when I was taking BASIC programming in HS, I wanted to get MS BASIC on the Atari becuase we were using MS BASIC on Apple II's in class. So I could do work for class on my Atari at home. But I never ended up getting it. Later on, I intended to get BASIC XE, but my love for programming was replaced with my love for working on the hardware itself, so that never happened either. These days the easy choice is Turbo BASIC XL; it's an advanced BASIC and all you need, and runs many times faster than any other choice I know about.
Is that MS BASIC cart useful at all on the Atari? If you want to type in old MS BASIC programs out of magazines or books. Otherwise you can't even use it to run MS BASIC programs from other computers until you convert them to a form the Atari disk format can understand, and then I'm sure there are some issues that will arise where program changes still need to be made before it will just run on an Atari, whether you type it in or get it loaded somehow.
Edited by Gunstar, Sun Feb 5, 2012 12:50 PM.
#16 morelenmir OFFLINE
morelenmir
    Space Invader
  • 38 posts
Posted Sun Feb 5, 2012 4:22 PM
I am currently fascinated by all and anything to do with programming on the 'A8' - as the cool kids say! I don't suppose anyone could point the way for me to a copy of the "MS Basic II" extension disk? I already have the cartridge thanks to Kr0tki and http://www.atariage....ost&pid=2306680
I have already grabbed the manual - so many thanks Mr Fish!!!
Second question - is the above-mentioned Turbo BASIC XL only available as a listing?
Edited by morelenmir, Sun Feb 5, 2012 4:35 PM.
#17 Sean39 OFFLINE
Sean39
    Moonsweeper
  • 280 posts
  • Atari 800 systems
Posted Sun Feb 5, 2012 4:34 PM
Hi
Ok first question to get out of the way is yes I am talking about Basic XE From O.S.S.
Yes that is the one you need the disk to get the extra extensions. Artical from Antic magazine covers how that Cart works with the disk and how fast it actually runs
Faster than the Version A basic and XL basic.
http://www.atarimaga...n9/basicxe.html
Now on to the other issue. I need the Microsoft basic because my daughter is learning how to program in it. I already have a computer setup for her.
I figure this would work great for her. Yes you are right a IBM with Microsoft basic is not going to load up on atari computer. Now the programs she is
learning how to write will work just fine with this version of Microsoft Basic since I see all the same command words and statements.
Gunstar you are right this would have been a great program to have back in the day when we had to learn Microsoft basic in school.
At one time in the late 1990's kids were lern Q-basic,so I am guessing her teacher just likes the Microsoft Version of basic.
They will eventually move on to assembly language and pascal
Which seem to be the languages used to most in writing complex programs.
I do not see people programing in fortran to much more these days.
Anyways the Microsoft basic is for my daughter since atari basic will not work in her school work. She still is programing in Atari basic just for her self
self satisfaction of doing it.
I do not have a copy of Turbo basic XL and do not know where to get a copy of it.
I am assuming this is not the XL basic on cartridge. If it is the XL basic Cartridge then I will have a copy of that soon,but will not have the disk that supports it.
Also I will not have the disk that supports the XE basic by O S S.
Thanks
Sean
#18 kheffington OFFLINE
kheffington
  • 1,368 posts
Posted Sun Feb 5, 2012 4:49 PM
Here is Microsoft Basic I, disk based doesn't need a utility disk.
Attached File  Microsoft Basic 1.0 (1981)(Microsoft).zip   30.25K   27 downloads
Here is Microsoft Basic II, not sure but think it is the utility disk.Give it a try and see.
Edited by kheffington, Sun Feb 5, 2012 5:02 PM.
#19 CharlieChaplin OFFLINE
CharlieChaplin
  • 1,293 posts
Posted Sun Feb 5, 2012 4:50 PM
Well,
here you are TB XL + Compiler + Runtime (for compiled TB XL programs). All programs here use english language (contrary to the original release of the Compiler which used german language) and come with english instructions. There is also a TB XL guide by Ron Fetzer added...
-Andreas Koch.
#20 AtariGeezer ONLINE
AtariGeezer
    Dragonstomper
  • 592 posts
Posted Sun Feb 5, 2012 4:54 PM
MS Basic II extension disk:
http://www.atariage....post__p__998152
Jay
#21 morelenmir OFFLINE
morelenmir
    Space Invader
  • 38 posts
Posted Sun Feb 5, 2012 5:10 PM
That was FAST guys!
For my own requests - MANY thanks indeed!!!
#22 russg OFFLINE
russg
    Dragonstomper
  • 523 posts
Posted Sun Feb 5, 2012 5:21 PM
View PostSean39, on Sun Feb 5, 2012 4:34 PM, said:
Hi
covers how that Cart works with the disk and how fast it actually runs Faster than the Version
Thanks
Sean
Microsoft BASIC II isn't going to be very useful for understanding currently used Visual BASIC.NET (VB.NET).
I suspect your daughter is getting Visual BASIC in school, not some BASIC like MS BASIC from the 1980s.
Here's a little information about VB.NET:
http://en.wikipedia....sual_Basic_.NET
I think you mention Pascal as a current developement tool. I don't think so. C# may be fairly current, I'm not
sure if any C is currently used much. I can't program in any current PC language.
For the PC, in DOS days, GWBASIC was used, then QuickBASIC in I guess up to the 90s. I have Visual BASIC 4
which is ancient and unsupported today. Visual BASIC is curently part of the .NET framework, whatever that means.
Your daughter can get some concepts with an old time BASIC, like MS BASIC II or Atari BASIC, but not what is
taught in schools today, I suspect.
Regards
( I never get good formatting with AA editor, there's always line breaks not where I put them.)
Edited by russg, Sun Feb 5, 2012 5:27 PM.
#23 morelenmir OFFLINE
morelenmir
    Space Invader
  • 38 posts
Posted Sun Feb 5, 2012 5:29 PM
From my own experience in current languages - C++ and VB, each tied to their own .NET variants seem to be the standards of the moment.
#24 Sean39 OFFLINE
Sean39
    Moonsweeper
  • 280 posts
  • Atari 800 systems
Posted Sun Feb 5, 2012 7:58 PM
Attachment Microsoft Basic 1.0 (1981)(Microsoft).zip
Attachment Microsoft Basic v2.0.zip
Hi I could download these files but I have no way of getting them onto the Atari 800 computer. I am borrowing this computer as it is.
I have a complete atari 800 set up with everything except the printer for now.
So the Zip files would do me no good.
So far I have the atari 800 with a 1050 drive,and the 850 serial port interface ,and a work 410 tape drive.
I do have 48K in the 800 computer. Anyways I have been trying to complete this for her to use. When my wife was killed in a car wreck we lost everything to pay for
funeral cost and hospital bills. We were in a car wreck a few years ago around Christmas time. it killed her grandparents and my wife,and the child my wife
was pregnant with. Which would have been my youngest daughter if they have lived.
The other driver was found at fault but had no car insurance and also only had a low paying part time job. She hit us at 60 mph head on. Left nothing
to the car. I have already represented this to the teacher. She said Microsoft Basic was fine on the Atari 800 computer. The teacher is an older teacher
and is well versed with the Atari 800 since years ago it was used in school when she taught. She taught when I went to school and I am in my mid 40's
She is going to have Microsoft basic on the school computers and said the one atari came out with is close enough to work with the programs she will
be starting out with.
My problem is getting the extension disk and a manual. I think I have found the manual for about $15.00 ,but I need that disk
I figure that you guys should know where I stand now in this mess.
Oh yes I did manage to get a commodore 1702 monitor,but the front lower cover is missing and the blue gun must be a little off on the right
side of the screen since I can see a slight blue line where the black boarder and main screen meet. When I change the back ground to another
color you can see that blue line barely above the color part of the screen which places it between the black boarder and
right part of the screen where text appears.(note it above,so it does not interfere with the text) . I know this means the blue gun is slightly off in the monitor.
Not sure if this means I will have to try and get another commodore 1702 monitor. I want to try and get the 80 collom generator for her.
This way I can get atari writer word 80 or something that will let her use a 80 collom screen for writing papers.
that bring me down to trying to get a good printer that I can hook up to the 850 serial/ parrel interface.
Well you guys now know why I have ask so many questions I am doing all of this for my daughter who just now turned 13 years old.
She like the atari 800 when I first had set it up just to play cartrige games at the age of 11,so she really likes computers like we
did. I have been trying to get thing for this computer over time. Hoping to complete it.
The Manual is for Microsoft basic II ,and so is the cart. So I will need to find a disk for that version. Or if someone could make me one
from those zip files.
Thanks everyone so much
Sean
Edited by Sean39, Sun Feb 5, 2012 8:24 PM.
#25 kheffington OFFLINE
kheffington
  • 1,368 posts
Posted Sun Feb 5, 2012 8:05 PM
Thanks
Sean
PM me the mailing address and I will write the ATR to disk and mail it to you.
