Question before building Covox
16 replies to this topic
#1 KubaCZ OFFLINE
KubaCZ
    Chopper Commander
  • 106 posts
Posted Mon Feb 6, 2012 12:51 PM
I've got some free time so I've decided to build covox using schematics on Lotharek's website:
Posted Image
Problem is that I can't find 74LS574, only 74HC(T)574... they look like they're same but maybe not? Also, can I just connect L + R output to stereo Pokey output or it needs to be seperated from it?
#2 BillC OFFLINE
BillC
    Moonsweeper
  • 495 posts
Posted Mon Feb 6, 2012 1:29 PM
Posted Image
Futurelec lists the 74LS574 for $1.25, I don't have any personal experience with them.
#3 candle OFFLINE
candle
  • 1,909 posts
Posted Mon Feb 6, 2012 1:51 PM
you can simply use hct
#4 ivop OFFLINE
ivop
    Chopper Commander
  • 123 posts
Posted Mon Feb 6, 2012 3:10 PM
HCT will probably even sound better as the signal transitions will be faster and synchronous. Think going from 127 to 128 where seven bits go from 1 to 0 and one bit goes vice versa. In CMOS technology, both transitions are equally fast. In NMOS technology, going from 1 to 0 is faster than the other way around, hence there will be a short value of zero in between 127 and 128.
As for mixing with pokey signals, a simple passive mixer will do, for example, route them through a 4k7 resistor and tie them together. If you use a 10k pot and use the wiper as output, you can adjust the balance as you see fit.
#5 KubaCZ OFFLINE
KubaCZ
    Chopper Commander
  • 106 posts
Posted Mon Feb 6, 2012 3:41 PM
Ok, thanks... tommorow I'll post results :)
#6 KubaCZ OFFLINE
KubaCZ
    Chopper Commander
  • 106 posts
Posted Tue Feb 7, 2012 11:12 AM
It works! :)
I didn't use 2k4 resistors but instead I used 820r, 1k6 ,3k3, 6k2, 12k, 24k, 47k and 91k. It sounds good in Inertia, but in Neotracker it's total mess.. adress is $D280, right?
#7 KubaCZ OFFLINE
KubaCZ
    Chopper Commander
  • 106 posts
Posted Tue Feb 7, 2012 3:16 PM
Oh, it's not on $D280 but on $D600... so now work both of them :)
It's funny how it sounds better than LPT dac's on 386-P1 computers.
#8 Mathy ONLINE
Mathy
  • 1,167 posts
Posted Tue Feb 7, 2012 4:11 PM
Hello KubaCZ
$D280 would be better. All PBI devices use $D600. Luckily with VBXE we have a choice between $D600 and $D700.
Mathy
#9 KubaCZ OFFLINE
KubaCZ
    Chopper Commander
  • 106 posts
Posted Tue Feb 7, 2012 5:23 PM
View PostMathy, on Tue Feb 7, 2012 4:11 PM, said:
Hello KubaCZ
Mathy
Hi Mathy
problem is that Inertia has D600 hardcoded I think and I want to have it working too... I'm using IDE+2 which is PBI and doesn't have any problem with it... only it makes noise when loading data but that's not big problem :)
#10 Mathy ONLINE
Mathy
  • 1,167 posts
Posted Tue Feb 7, 2012 5:38 PM
Hello KubaCZ
"Hardcoded" doesn't mean that much anymore. There should be more them enough people here that can change $D600 into $D280.
Mathy
#11 Fox-1 / mnx OFFLINE
Fox-1 / mnx
    Dragonstomper
  • 938 posts
  • BBSing is terminal...
Posted Tue Feb 7, 2012 8:31 PM
Inertia Player 4.0 can be set manually to $D5, $D6 and $D7
#12 Stephen OFFLINE
Stephen
  • 3,250 posts
  • A8 Gear Head
Posted Tue Feb 7, 2012 8:46 PM
Is there a way to get Inertia ( I think I have 4.5) to work with a Covox wired to $D280?
#13 Fox-1 / mnx OFFLINE
Fox-1 / mnx
    Dragonstomper
  • 938 posts
Posted Tue Feb 7, 2012 8:58 PM
Possibly. May be as easy as altering the code with a sector editor (changing 80D2 to 00d6) but never looked into the code.
#14 Stephen OFFLINE
Stephen
  • 3,250 posts
  • A8 Gear Head
Posted Tue Feb 7, 2012 10:31 PM
K - I'll try that.
#15 Fox-1 / mnx OFFLINE
Fox-1 / mnx
    Dragonstomper
  • 938 posts
Posted Wed Feb 8, 2012 9:39 AM
It's actually reversed. You need search for 00D6 ($D600) and change it to 80D2 ($D280) but I guess you'll get the point :-)
#16 Mathy ONLINE
Mathy
  • 1,167 posts
Posted Wed Feb 8, 2012 1:41 PM
Hello guys
IIRC there were/are two versions of Inertia. Where the version with the lower version number was actually the latest version, or the version with more options.
Mathy
#17 CharlieChaplin OFFLINE
CharlieChaplin
  • 1,293 posts
Posted Wed Feb 8, 2012 2:59 PM
Well,
there were half a dozen or more versions of Inertia, alas, I have only three of them (versions 2.x, 3.x and 4.5). Attached them here, as well as some other Covox software, like Pro-Tracker and Neo-Tracker (v1.6 on ATR, v1.7 and v1.8 as XEX)
-Andreas Koch.
