New 8-bit power supplies on eBay
13 replies to this topic
#1 Allan OFFLINE
Allan
  • 4,249 posts
Posted Mon Feb 6, 2012 2:48 PM
Does anybody know about these new xe/xl power supplies that are on eBay? Are they any good? Any advantage to them?
eBay Auction -- Item Number: 230742274234
Allan
#2 Fox-1 / mnx OFFLINE
Fox-1 / mnx
    Dragonstomper
  • 938 posts
  • BBSing is terminal...
Posted Mon Feb 6, 2012 4:09 PM
They probably work but these aren't Atari power supplies. Just a generic one with an Atari connector put on.
#3 Bryan OFFLINE
Bryan
  • 7,626 posts
  • Cruise Elroy = 4DB7
Posted Mon Feb 6, 2012 4:41 PM
Someone is putting the Atari DIN on a small switching supply. Seems like a good idea to me since the failure mode of switchers is typically no output or noisy output rather than increased voltage as is often the case with linear supplies.
#4 Stephen OFFLINE
Stephen
  • 3,250 posts
  • A8 Gear Head
Posted Mon Feb 6, 2012 7:32 PM
I built myself a similar one, using a 2.4Amp switching supply built by DVE. I think it powered a router or switch at one time. It's tiny, lightweight, and puts out no heat.
#5 orpheuswaking OFFLINE
orpheuswaking
  • 4,024 posts
  • Lone Raider Time!
Posted Mon Feb 6, 2012 11:08 PM
The nice thing about them is that they are mostly higher amps which is good if you have a lot of modifications in your machine.
#6 flashjazzcat OFFLINE
flashjazzcat
  • 5,410 posts
  • Jumping through hOOPs...
Posted Tue Feb 7, 2012 6:15 AM
These are exactly the kind I build myself. Small size, high amps, and hopefully pretty safe.
#7 bbking67 OFFLINE
bbking67
    Star Raider
  • 98 posts
Posted Tue Feb 7, 2012 7:20 AM
With a 5V DC power supply, what is the minimum current required? Some of my Ataris have 1.5A and other 1A power supplies... if I use a switching power supply (I have one from an old router) can I get away with 1.5A or is it better to use a 2A or 2.5A supply?
These should be easy enough to find in the Value Village wall of junk...
Are the 1050 supplies replacable? I see that they are 9VAC, but 3.4A! I haven't got anything that big...
#8 w1k OFFLINE
w1k
    Dragonstomper
  • 745 posts
Posted Tue Feb 7, 2012 7:32 AM
question of year :D:
can i power my atari with batteries?
#9 sloopy OFFLINE
sloopy
  • 2,258 posts
  • lookin for bits, i like bits...
Posted Tue Feb 7, 2012 8:12 AM
For a stock machine, a 1A is fine, but if you have or are planning on adding internal upgrades, a 1.5A or larger is suggested. Anything over 2A will work but is overkill.
2.0/2.1A 5V wall warts are common on USB hubs. You can commonly get one for $10 or less with wallwart at most discount stores and other places.
w1k: batteries? sure, one car battery will work with a voltage regulator...
sloopy.
#10 Allan OFFLINE
Allan
  • 4,249 posts
Posted Tue Feb 7, 2012 9:34 AM
Thanks for the responses guys.
Allan
#11 BillC OFFLINE
BillC
    Moonsweeper
  • 495 posts
Posted Tue Feb 7, 2012 2:25 PM
1050s can be modified to run using a dual voltage regulated +5/+12V power supply, since that's what the rectifiers/regulators convert it to. This also eliminates a lot of heat from the inside of the drive.
#12 Bryan OFFLINE
Bryan
  • 7,626 posts
Posted Tue Feb 7, 2012 6:56 PM
Even simpler is to run 12V into the drive and power the 5V regulator off it.
#13 bbking67 OFFLINE
bbking67
    Star Raider
  • 98 posts
Posted Thu Feb 23, 2012 6:00 PM
how do you do that? is that 12V DC Bryan?
Edited by bbking67, Thu Feb 23, 2012 6:00 PM.
#14 Bryan OFFLINE
Bryan
  • 7,626 posts
Posted Thu Feb 23, 2012 6:12 PM
Yes, the drive converts the AC coming in to 5V and 12V. If you modified the drive, you could run 12VDC directly in and run the 5V regulator off that. Basically, you would remove the 12V regulator and connect 12V to it's OUT pad. Looking at the schematic, you could probably leave everything else alone as long as the supply was tip positive.
pos -o)- neg
Oh yeah, you'd also need to connect the negative to the drive's ground (after the power switch, though).
Here's what I think will work (not tested):
Get a 12V regulated supply. 2A or more recommended. Tip positive with the correct barrel plug.
Remove regulator Q8 and jumper from the junction of CR17 and CR20 to the third pad of Q8.
Solder a jumper across CR19.
