Moonpig, on Thu Feb 9, 2012 3:04 AM, said:
After doing some research and talking to some people who offer a UK modding service, I am confused which is the best method to use.
DIY Kit
eBay Auction -- Item Number: 300592126324
When I asked another modder if he used the kits he said
“No, I didn't use that kit. I got my parts separately.
To be honest, I would never use those standard connections. I only use gold connections as they produce better quality.
The parts used for this mod are widely available, you just have to know what you are looking for. Also its cheaper than that kit.”
Are the kits better than buying the bit separately, or do they produce equally good results and I should just go with which method is cheaper?
Also are there any other kits available for a PAL Atari 2600?
Thanks
Those kits you reference in the eBay link are Mike Pagano's mod kits and service - - he is an EXCELLENT individual to deal with and sells a very simple and effective pre-made mod kit for all models of ATARI 2600s.
I have purchased multiple mod kit units from him, and have been very pleased.
HOWEVER, from personal experience I have determined that the kits were designed primarily for NTSC units.
I think that his mod kits MIGHT work for some ATARI 2600 PAL models, but I attempted to use one on a PAL ATARI 2600 Jr and was only able to get black and white, which means it is not pulling the components from the right place. Further testing on all the known "pickup points" on the PAL board still did not produce results with that mod kit, and so I moved onto other methods.
You mileage may vary, though - - I want to stress that Mike is a VERY helpful individual and would do his best to get your system correctly set up!
You might do better sending it to him for the service, rather than buying a kit, though.
**OR, might I suggest a mod for a PAL Atari 2600 Jr system that I found on a German forum? See the attached PDF.
Junior Atari 2600 video mod without additional board.pdf 1.53MB
49 downloads
This is very specific for a 2600
Jr, but it might be adaptable for whatever unit you are working on.
What type of ATARI 2600 are you working with? A four-switch woody or Vader, perhaps?
I am planning to implement this method myself (I was actually just laying out the parts this morning) and I will let you know how it goes. I plan to use a small board, rather than going direct to the PCB as the author seems to prefer, but that's just personal preference.
Best of luck!
-a2a
