Metal Ghost Posted February 13, 2012 Share Posted February 13, 2012 Can I get some help from someone perhaps with Photoshop? I'm trying to get the RGB and/or CMYK values for the Legend of Zelda box....specifically the gold background and red contained in the box. I tried to do a color sample, but once I have created a swatch the color that's saved looks VERY washed out compared to the sample I'm working off of (which I downloaded from the coverproject.net). I'm not sure if there's something going on in the sampling process or something else. Thanks! Quote Link to comment Share on other sites More sharing options...
Metal Ghost Posted February 14, 2012 Author Share Posted February 14, 2012 I'm confident that someone knows this or can find out Quote Link to comment Share on other sites More sharing options...
Metal Ghost Posted February 17, 2012 Author Share Posted February 17, 2012 Not giving up! Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted February 17, 2012 Share Posted February 17, 2012 Taken from this :- http://www.thecoverproject.net/view.php?cover_id=2476 Quote Link to comment Share on other sites More sharing options...
Metal Ghost Posted February 17, 2012 Author Share Posted February 17, 2012 Taken from this :- http://www.thecoverp...p?cover_id=2476 Thanks for the reply Groovy. No, I have the actual colors....got them from the cover project too, actually. The problem I'm having is that when I color sample them within InDesign and get the RGB numerical values, and subsequently use those Swatches in a spread, they look VERY washed out. For 'Zelda Gold', after sampling the cover that I downloaded from the Cover Project, RGB values it returns are 187/149/84. For 'Zelda Red', it's 229/11/24. If someone else can sample those in InDesign, or Photoshop, or anything else I'd like to see if for some reason my values are coming back incorrect, or if it's showing up as washed out for some other reason. I'll also try to take and attach a screenshot to show what I'm talking about. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted February 17, 2012 Share Posted February 17, 2012 Are you sure that your app's gamma correction is set up correctly? Quote Link to comment Share on other sites More sharing options...
Metal Ghost Posted February 17, 2012 Author Share Posted February 17, 2012 Thanks....I enabled color management and it appears MUCH better now. I hadn't realized that it was not enabled by default. Quote Link to comment Share on other sites More sharing options...
Brian O Posted February 17, 2012 Share Posted February 17, 2012 There's also a bunch of RGB to CMYK converters like this one and this one. Some of these give you pretty accurate results, as long as you have a good RGB sample to work from. -B Quote Link to comment Share on other sites More sharing options...
