Mclaneinc Posted May 14, 2012 Share Posted May 14, 2012 This is not my bug report, it was spotted by a user named Daniel on the blog, just posting it on here because Avery is often found on here and as he is busy I guessed a spread between blog and here was the best way to catch his eye. Here's what Daniel had to report Atirra's cheater has one bug. If I set cheat value to any value less than 256 or $100, it always write 8 bit only, no matter I select 8 bit or 16 bit mode. I suggest more features should be added below: Search box in cheat dialog box should support hexacimal values and multiple hexacimal values in addition to decimal values and should search by 8 bit, 16 bit, 32 bit, reverse 16 bit and reverse 32 bit. I like to add reverse 16 bit, 32 bit and reverse 32 bit to cheat value, not just 8 bit and 16 bit. Quote Link to comment Share on other sites More sharing options...
danielcg Posted May 15, 2012 Share Posted May 15, 2012 Atirra Cheat Bug Report Update 16 bit cheat did not work properly, no matter what value I set. 16 bit cheat always use only least significant 8 bit. I did selected 16 bit mode in dialog box. I verified the bug with BASIC POKE and PEEK commands. Example: If I set $600 (1536) to $101 (257), PEEK(1536) returned 1, this is correct but PEEK(1537) returned 0, this is not modified and incorrect. Address $600 to $6FF are not used by Atari OS, DOS and BASIC. Quote Link to comment Share on other sites More sharing options...
