Cybearg Posted March 7, 2013 Share Posted March 7, 2013 Is there any way that I could have abstract references to memory locations, either in bB alone or with a combination of bB and Assembly? For instance, let's say that I have a number of sprites on screen: player0 player1 player2 player3 player4 player5 ... Now in order to do anything with those, I'd have to perform the same checks on each of them, bogging down the code and slowing things down: if i then goto player0 player1 player2 player3 player4 player5 player0 if missile0x <= player0x + 4 && missile0x >= player0x && missile0y <= player0y + 8 && missile0y >= player0y then goto confirmed_hit else i = i + 1: goto denied_hit player1 if missile0x <= player1x + 4 && missile0x >= player1x && missile0y <= player1y + 8 && missile0y >= player1y then goto confirmed_hit else i = i + 1: goto denied_hit ... etc. Is there some way that I could, for instance, set up an array to point to the memory locations (the below locations are based on this)? data spritex $87, $88, $89, $8a, $8b, $8c end data spritey $8d, $8e, $8f, $90, $91, $92 end if missile0x <= spritex[i] + 4 && missile0x >= spritex[i] && missile0y <= spritey[i] + 8 && missile0y >= spritey[i] then goto confirmed_hit else i = i + 1: goto denied_hit ... Or, since memory locations are often defined in a row, something like: dim sprite0x = $87 dim sprite0y = $8d if missile0x <= spritex[i] + 4 && missile0x >= spritex[i] && missile0y <= spritey[i] + 8 && missile0y >= spritey[i] then goto confirmed_hit else i = i + 1: goto denied_hit (which would work kind of like a[0] = a, a[1] = b, a[2] = c, etc.) ... Or maybe through the use of inline assembly? (I like the use of arrays best because, while it takes more space to define the arrays, it gives you control over what is being indexed) data spritex 87, 88, 89, 8a, 8b, 8c end data spritey 8d, 8e, 8f, 90, 91, 92 end temp1 = spritex[i] temp2 = spritey[i] asm LDA $temp1 STA temp3 LDA $temp2 STA temp4 end if missile0x <= temp3 + 4 && missile0x >= temp3 && missile0y <= temp4 + 8 && missile0y >= temp4 then goto confirmed_hit else i = i + 1: goto denied_hit If none of these, is there some other way? Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 7, 2013 Author Share Posted March 7, 2013 Alright, I've been doing some experiments. So far, I can confirm that the second method works: dim pt0x = $80 dim pt0y = $85 player0: %11111111 %11111111 %11111111 %11100111 %11100111 %11111111 %11111111 %11111111 end player1: %11111111 %11111111 %11111111 %11100111 %11100111 %11111111 %11111111 %11111111 end data spritex 40, 60 end data spritey 40, 60 end main_loop rem player0 is red, player1 is green COLUP0 = $40 COLUP1 = $C0 for i = 0 to 1 pt0x[i] = spritex[i] pt0y[i] = spritey[i] next drawscreen goto main_loop I'll be testing the other methods to see what I find. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 7, 2013 Author Share Posted March 7, 2013 (edited) So far, I haven't found a way to abstractly reference memory locations from an array. I've tried methods one and three above, but neither works, though it's possible that my syntax is wrong and that there's another way to do it. Anyone know? I did find a less elegant but still effective way that works effectively about like how an array would: player0: %11111111 %11111111 %11111111 %11100111 %11100111 %11111111 %11111111 %11111111 end player1: %11111111 %11111111 %11111111 %11100111 %11100111 %11111111 %11111111 %11111111 end data spritex 40, 60 end data spritey 40, 60 end main_loop rem player0 is red, player1 is green COLUP0 = $40 COLUP1 = $C0 for i = 0 to 1 temp1 = spritex[i] temp2 = spritey[i] gosub storei next drawscreen goto main_loop storei on i goto pl0 pl1 pl0 asm LDA temp1 STA $80 LDX temp2 STX $85 end return pl1 asm LDA temp1 STA $81 LDX temp2 STX $86 end return The part I don't like is that, unless you want to repeat the on-goto statement or just inline add enough assembly to account for the different values of i, it requires an on-goto on top of a gosub, which is a bit pricey, cycle-wise. And then, you'd another entire subroutine for reading those memory locations, which means another on-goto and another gosub. It's more space-efficient than just writing everything out, but I don't know if the loss of cycles are worth it. Maybe someone else has a better idea for how it can be done more efficiently. EDIT: I suppose that, technically, there's no reason to use anything besides the method in the post above this one, since, if memory values don't align properly to use the a method, one can always re-map the kernel's memory locations by simplify modifying the 2600basic.h, multisprite.h, or DPCplus.h files so that they do line up. Edited March 7, 2013 by Cybearg Quote Link to comment Share on other sites More sharing options...
bogax Posted March 7, 2013 Share Posted March 7, 2013 (edited) What kernel/kernel options are you using ? edit I'm having trouble following your code. I think what you want for that last bit would be data spritex 40, 60 end data spritey 40, 60 end main_loop rem player0 is red, player1 is green COLUP0 = $40 COLUP1 = $C0 for i = 0 to 1 player0x[i] = spritex[i] player0y[i] = spritey[i] next drawscreen goto main_loop let me rephrase that I'm not sure that's what you want I think that's what you're doing. Edited March 8, 2013 by bogax Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 8, 2013 Author Share Posted March 8, 2013 (edited) What kernel/kernel options are you using ? edit I'm having trouble following your code. I think what you want for that last bit would be data spritex 40, 60 end data spritey 40, 60 end main_loop rem player0 is red, player1 is green COLUP0 = $40 COLUP1 = $C0 for i = 0 to 1 player0x[i] = spritex[i] player0y[i] = spritey[i] next drawscreen goto main_loop let me rephrase that I'm not sure that's what you want I think that's what you're doing. Yeah, that's basically what I'm doing. The reason for the weird way I did it, redefining the player variables, is because I wanted to find a way to reference any memory location, not just ones that were necessarily defined in a row. For instance, let's say I'm using missile0, missile1, and the ball along with sprites. I was hoping for a way to map them, using an array or otherwise, so that they could be listed as: player0 player1 player2 player3 player4 player5 missile0 missile1 ball ... or in any other order I prefer: player4 ball player2 player3 missile1 player0 missile0 player1 ... etc. That was my overall goal--to be able to list memory locations in any order I desire and still reference them with an index. If you can think of any way to do that, please do let me know. The above example with real memory locations used the standard kernel, but ideally there would be a method that would fit for any kernel. Edited March 8, 2013 by Cybearg Quote Link to comment Share on other sites More sharing options...
bogax Posted March 8, 2013 Share Posted March 8, 2013 You could put your mapping into table and do something like this. const mem = 0 const player0 = 0 const player1 = 1 const player2 = 2 const player3 = 3 const player2 = 4 const player3 = 5 const missle0 = 6 const missle1 = 7 const ball = 8 dim xptr = temp1 dim yptr = temp2 data x_ptrs player0x, player1x, player2x, player3x, player2x, player3x, missle0x, missle1x, ballx end data y_ptrs player0y, player1y, player2y, player3y, player2y, player3y, missle0y, missle1y, bally end for i = 0 to 1 xptr = x_ptrs[i] yptr = y_ptrs[i] mem[xptr] = spritex[i] mem[yptr] = spritey[i] next Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 8, 2013 Author Share Posted March 8, 2013 (edited) I don't follow what you're doing there. How would that be able to set values to and from player x/y positions? Is one able to make an array consisting of variables? I was under the impression only actual values were allowed. Since your code is incomplete (you reference spritex and spritey without defining them anywhere), I assume it's supposed to integrate with some of the stuff I wrote above? Edited March 8, 2013 by Cybearg Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted March 8, 2013 Share Posted March 8, 2013 Are you talking about expecting some sort of inheritance? Where you could go enemy.x = 134 and every object whose parent is enemy would get their x coordinate changed? Quote Link to comment Share on other sites More sharing options...
RevEng Posted March 8, 2013 Share Posted March 8, 2013 Any on-the-fly reordering of memory locations is going to have a cycle and rom space penalty, so its best to avoid that. bB already orders all similar variables together - player0x, player1x, etc. - so you can operate in a loop. Which variables do you need to operate on in sequence? Quote Link to comment Share on other sites More sharing options...
bogax Posted March 8, 2013 Share Posted March 8, 2013 (edited) I don't follow what you're doing there. How would that be able to set values to and from player x/y positions? Is one able to make an array consisting of variables? I was under the impression only actual values were allowed. Since your code is incomplete (you reference spritex and spritey without defining them anywhere), I assume it's supposed to integrate with some of the stuff I wrote above? I'm still not sure what you're trying to do so that may not be helpful. The variable names are constants, I just put them in a table so they could be indexed. To get your indirection you have to look them up and put them in a variable to use as a pointer since bB doesn't allow for indirection to go any deeper than that. I used temp variables renamed to xptr, yptr And yes I was just applying it to the previous little bit of code as an example. The only reason I could see for doing it that way is for indexing as in the for next loop but you could in principle do it with named constant (hence the constant definitions of table indexes) You'd still have to do the look ups rem this writes x to player0x xptr = x_ptrs[player0] mem[xptr] = x rem this reads x from player0x xptr = x_ptrs[player0] x = mem[xptr] You could put stuff like that into macros and/or subroutines I suppose but I'm not sure you need anything that general? As RevEng points out they're all ready mostly in order if you're counting through indexes. If you want something more random access or arbitrary it's going to cost you, but it could probably be done. The question is what will it save you? What are you trying to do specifically? Edited March 8, 2013 by bogax Quote Link to comment Share on other sites More sharing options...
Cybearg Posted March 8, 2013 Author Share Posted March 8, 2013 Well, I ended up remapping the memory locations and then using the second method described in the first post. I just want to be able to reference different sprites (whether they're players, missiles, or the ball) based on an index. I couldn't normally do it because the memory map doesn't quite allow it, but adjusting values made it possible: ; multisprite stuff below - 5 bytes each starting with spritex SpriteIndex = $80 player0x = $81 NewSpriteX = $82 ; X position player1x = $82 player2x = $83 player3x = $84 player4x = $85 player5x = $86 missile1x = $87 ballx = $88 missile0x = $89 player0y = $8A objecty = $8A NewSpriteY = $8B ; Y position player1y = $8B player2y = $8C player3y = $8D player4y = $8E player5y = $8F missile1y = $90 bally = $91 missile0y = $92 This allowed me to turn this: leap on closepixel goto leapzero leapone leaptwo leapthree leapfour leapfive leapsix leapseven leapzero if player0x = player1x - 4 && player0y = player1y + 10 then return if player0x > player1x - 4 then player0x = player0x - 1 if player0x < player1x - 4 then player0x = player0x + 1 if player0y > player1y + 10 then player0y = player0y - 1 if player0y < player1y + 10 then player0y = player0y + 1 return leapone if player0x = player2x - 4 && player0y = player2y + 10 then return if player0x > player2x - 4 then player0x = player0x - 1 if player0x < player2x - 4 then player0x = player0x + 1 if player0y > player2y + 10 then player0y = player0y - 1 if player0y < player2y + 10 then player0y = player0y + 1 return leaptwo if player0x = player3x - 4 && player0y = player3y + 10 then return if player0x > player3x - 4 then player0x = player0x - 1 if player0x < player3x - 4 then player0x = player0x + 1 if player0y > player3y + 10 then player0y = player0y - 1 if player0y < player3y + 10 then player0y = player0y + 1 return leapthree if player0x = player4x - 4 && player0y = player4y + 10 then return if player0x > player4x - 4 then player0x = player0x - 1 if player0x < player4x - 4 then player0x = player0x + 1 if player0y > player4y + 10 then player0y = player0y - 1 if player0y < player4y + 10 then player0y = player0y + 1 return leapfour if player0x = player5x - 4 && player0y = player5y + 10 then return if player0x > player5x - 4 then player0x = player0x - 1 if player0x < player5x - 4 then player0x = player0x + 1 if player0y > player5y + 10 then player0y = player0y - 1 if player0y < player5y + 10 then player0y = player0y + 1 return leapfive if player0x = missile1x - 4 && player0y = missile1y + 10 then return if player0x > missile1x - 4 then player0x = player0x - 1 if player0x < missile1x - 4 then player0x = player0x + 1 if player0y > missile1y + 10 then player0y = player0y - 1 if player0y < missile1y + 10 then player0y = player0y + 1 return leapsix if player0x = ballx - 4 && player0y = bally + 10 then return if player0x > ballx - 4 then player0x = player0x - 1 if player0x < ballx - 4 then player0x = player0x + 1 if player0y > bally + 10 then player0y = player0y - 1 if player0y < bally + 10 then player0y = player0y + 1 return leapseven if player0x = missile0x - 4 && player0y = missile0y + 10 then return if player0x > missile0x - 4 then player0x = player0x - 1 if player0x < missile0x - 4 then player0x = player0x + 1 if player0y > missile0y + 10 then player0y = player0y - 1 if player0y < missile0y + 10 then player0y = player0y + 1 return into this: leap temp1 = pixelx[closepixel] - 4 temp2 = pixely[closepixel] + 10 if player0x > temp1 then player0x = player0x - 2 if player0x < temp1 then player0x = player0x + 2 if player0y > temp2 then player0y = player0y - 2 if player0y < temp2 then player0y = player0y + 2 Quote Link to comment Share on other sites More sharing options...
