Wildstar Posted November 10, 2014 Share Posted November 10, 2014 This is a branching discussion from the VDP tricks so I'm planning to move the discussion regarding FLI and similar tricks using the F18A VDP so as to reduce confusion. http://www.atariage.com/forums/topic/231597-vdp-scanline-tricks/ Reference posts #'s: #6 #16 #23 #24 #25 Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 10, 2014 Share Posted November 10, 2014 I don't really have anything to add until new information becomes available... but I suppose I can give you the test program I did. You'll need a MiniMemory though, I entered it by hand in EasyBug. (You have to manually change the color table so that space has a transparent background color). I tried a number of variations of this, but this version of the code was trying to do 64 palette changes per scanline. It basically polls for the blanking bit, then runs a countdown loop 64 entries long, each time inverting the color of palette entry 0. This gives a nice dramatic display which shows the jitter well. You can also see how it jumps when the CPU access the VDP (since EasyBug is still running). * test for minimem * F18A GPU just changing BG color as fast as possible AORG >7000 * save return address MOV R11,R10 LI R9,VDPADR * we use this a lot * Copy GPU program to VDP LI R0,>4400 * vdp write address >400 BL *R9 LI R0,GPUST LP MOVB *R0+,@VDPWD CI R0,GPUEND JNE LP * Unlock F18A LI R0,>B91C * VR1/57, value 00011100 BL *R9 * write once (corrupts VDPR1) BL *R9 * write again (unlocks enhanced mode) LI R0,>81E0 * restore VDPR1 BL *R9 * Start F18A GPU at >0400 LI R0,>B604 * MSB BL *R9 LI R0,>B700 * LSB (will start program) BL *R9 * and back to EasyBug B *R10 * Write address or register VDPADR SWPB R0 MOVB R0,@>8C02 SWPB R0 MOVB R0,@>8C02 B *R11 * GPU program (using relative code) * VDP registers start at >6000 in GPU memory space GPUST LI R1,>5000 * color palette register #0 LI R2,>7000 * scanline+blanking register LI R3,>0001 * blank bit GPULN CLR R0 LI R4,64 * how many loops GPULP MOV R0,*R1 INV R0 DEC R4 JNE GPULP * now immediately wait for hblank * (will also trigger during vblank) GPUWT COC *R2,R3 * is it set? JNE GPUWT * no JMP GPULN * yes! GPUEND idle NEXT END Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 10, 2014 Share Posted November 10, 2014 Oh! I should mention that it's helpful to know how to stop the GPU program, which you should do before uploading changes (to prevent unexpected behavior). See the last JMP right above GPUEND? When you enter the code into Easy Bug, take a note of what address it's at, and then use the offset from GPUST to work out where in VDP RAM it's running (VDP program loads at >0400). Once you find it, it will be "F0 xx" (where xx is the negative jump). Replace that 'xx' with '00' in EasyBug and the code will fall through to the IDLE and stop the GPU. (Code modification needs to be single byte changes, since you can't write from the 9900 fast enough to change two bytes in time ). Quote Link to comment Share on other sites More sharing options...
