0
Cable Selection
3 replies to this topic
#1 Intrepid OFFLINE
Intrepid
    Chopper Commander
  • 142 posts
Posted Thu May 15, 2003 6:32 PM
I'm getting a new TV next week and therefore will have the inputs I've been wanting for so long. :D
I need to decide what new cabling to buy to take full advantage of my new setup.
This TV comes with 4 A/V inputs, including:
3 composite video (2 rear, 1 front)
2 S-video (1 rear, 1 front)
1 component video (rear)
That's essentially 3 rear inputs and an aux front input.
The component will very likely go to the PS2 as I use it as a DVD player also. The rear S-video will likely go to the DreamCast, and the composite will go to the NES (routed through the VCR, as it's a 2 birds with 1 stone there).
What I'd like to know is what other systems are worthy of investing in S-Video cabling to really improve the picture. My personal most likely candidate is the Saturn.
My thoughts on optimal cabling per system are as followed:
Component:
PS2*
XBox
Game Cube
DreamCast*
S-Video:
Saturn*
Composite:
Genesis*
NES*
SNES*
Coax:
Pong Systems*
Odyssey^2*
Atari 2600/5200/7800*
Sega Master System
TG-16
Should there be any modifications to this recommendation? I'm considering the units under stock configuration, no A/V mods allowed. All coax units bypass RF switchboxes and use a phono to F adapter. Some systems (such as the N64) are left off because I do not know enough about their practical usage.
*= systems I own
#2 ussexplorer OFFLINE
ussexplorer
    Dragonstomper
  • 747 posts
Posted Fri May 16, 2003 1:12 AM
What switch box are you going to use? I have several game systems and I know if I link all the rf units together. It gives one crappy signal. So I sortof got something like what you got
SMS - RF
SEGA Genesis - A/V
SNES - A/V
Atari 7800/2600 RF
The bigest problem is trying to find one that is cheap and yet covers both RF/AV
Laters,
Josh
#3 Intrepid OFFLINE
Intrepid
    Chopper Commander
  • 142 posts
Posted Fri May 16, 2003 9:25 AM
Well, the TV has 2 coax inputs, so I'll be using 1 for cable and 1 for games. Will probably run the 7800 through the SNES through the Genesis RF. That's what I was doing before. The picture doesn't degrade too badly, and I'll eventually buy AV cables for the SNES and Gen and hook them too a switcher. If the picture is actually that bad, I still have my old A/B coax switch I can use to reduce the number of systems that get passed through.
#4 Ze_ro OFFLINE
Ze_ro
  • 8,511 posts
  • Welcome Back!
Posted Fri May 16, 2003 12:23 PM
If you're really that concerned about picture quality... I'd recommend you get a TV/monitor that's capable of RGB. Unfortunately, not many TV's have these, so any one that you find will be fairly expensive (Although I believe most European TV's have SCART connectors, which have RGB capabilities). However, I've never seen a better picture than that provided by an RGB connection.
For a cheap solution, look for an old Commodore 1084S monitor... they support RGB perfectly, but they're rather small (compared to your 36" TV anyways). I have my Jaguar hooked up to one through an RGB cable, and it looks excellent.
--Zero
