0
Need Help With Model 1 Genesis and Sega cd Unit
7 replies to this topic
#1 shaggy OFFLINE
shaggy
    Moonsweeper
  • 364 posts
Posted Thu Jun 19, 2003 7:14 PM
I recently picked up a Model 1 Genesis and a Sega CD unit. It came with a power supply and an RF connector. I have these connected to the Genesis and it works fine. Now what else do I need to get the CD unit to work. I need another power supply and A/V cables don't I? Does anyone have any extra ones or pics? Does anyone also have a manual and could scan pics for me so I can see the hookup? Thanks for your guys help.
#2 Xot OFFLINE
Xot
  • 4,559 posts
  • Because I'm -- A NINJA!!
Posted Thu Jun 19, 2003 10:03 PM
You don't need AV cables. Plug your RF connector into the Genny and then to the TV and that's enough to work.
Is the SCD unit model 1 or 2 (Front or Top loading)? There's a connector "bridge" for the Model 1 SCD unit that you may be missing.
As far as PS, a Genny Model 1 PS works for both models of SCD.
#3 shaggy OFFLINE
shaggy
    Moonsweeper
  • 364 posts
Posted Sun Jun 22, 2003 11:12 AM
I have the unit that goes underneath the Genesis.
#4 IceCold OFFLINE
IceCold
  • 2,666 posts
Posted Sun Jun 22, 2003 11:13 AM
Both go underneith the genesis...
#5 Happy_Dude OFFLINE
Happy_Dude
  • 4,208 posts
  • Forum Slacker
Posted Sun Jun 22, 2003 11:25 AM
You mean the Genny 1 right. The model 2 CD sits "next" to the model 2 main unit, not under it ;)
And I didn't know a model 2 CD could be used with a model 1 console :?
#6 IceCold OFFLINE
IceCold
  • 2,666 posts
Posted Sun Jun 22, 2003 11:55 AM
That's not true. The genesis sits on top of the model 2 unit. But since the sega cd is bigger than the genesis, the cd door is next to the genesis.
The genesis is still on top of the sega cd though...
#7 shaggy OFFLINE
shaggy
    Moonsweeper
  • 364 posts
Posted Sun Jun 22, 2003 2:32 PM
No it doesn't. The CD unit that works with the Model 1 Genny attaches underneath and the CD unit that works with the Model 2 Genny attaches to the side of it. Now there is a base that the Model 2 Genny sits on but this is NOT the CD unit... it is a base. And I am positive that the 2 units are not interchangeable with the other Model units, i.e. Model 1 Genny will not attach to the Model 2 CD system and vice versa.
#8 Artlover OFFLINE
Artlover
    Super Amazing Guy
  • 6,354 posts
  • Bad ass mother 3000, twice as fast as your ass.
Posted Sun Jun 22, 2003 7:47 PM
Not exactly correct.
The original Model 1 Genesis will work with either model Sega CD unit just fine.
The original front loading model 1 SegaCD that the Model 1 Genesis sat on top of still connected to the Genny's side port via a right angle stick-up connector on the right side of the CD unit. It had a 1/8" stereo audo-in jack that connected to the Genesis's headphone jack to allow the Genny's sound to be passed through the CD unit.
The second top-loading model 2 SegaCD came with a base extension to screw on to the base section to give it the same footprint as an original Genesis. It also had a 1/8" stereo audio-in jack to connect to a model 1 Genesis's headphone jack.
Both CD units came with the 1/8" stereo patch cable for connecting model 1 Genesis audio.
Model 2 Sega Geneis's do not officaly work with an original top-loading SegaCD unit. They will, but you won't get Genesis generated sound. This is because the model 2 Genesis has audio-out on the expansion connector and no headphone connector, where-as the model 1 Genesis doesn't have expansion port audio-out, and does have a headphone connector.
The model 2 SegaCD was built to use either one (expansion audio-out, or patch cable from the headhpone jack), but the original model 1 SegaCD only supported the headphone patchcable.
But if you make your own cable, you can still use them together. If I remember, you just need to tap off the audio-out points of the model 2 Genesis, and route them to a 1/8" stereo plug to connect to the model 1 SegaCD, and you should be all set.
I also believe the metal RF shield/mounting plate of the model1 SegaCD will not mate up with a model 2 Genesis correctly, so you won't have to bother with attaching it. You may or may-not have RF issues. The SegaCD's & Genesis's were all pretty hit or miss about that. Some needed the plate, some didn't.
