Z26X - Atari 2600 Emulator for XBox v2
Features :
- Emulates the Atari 2600
- Accurate Pitfall 2 emulation and SuperCharger emulation
- Near perfect compatibility - ported from Z26
- Cheat system - Search/Create your own cheat codes (see notes)
- Favorites list
- Netplay
- Resizable game screen
- Save Game management - delete save game files
- Skin-able :
- Backgrounds
- Sounds
- Background Music
- Sprites
- Text position (right/left/center, top/bottom/center)
- Text color, select bar color
- Font
- Fading speed
- Screenshot position
- Can specify 2 sprites to surround the selected menu option
- Option to have a transparent select-bar color (from select-color menu)
- Can flip sprites horizontally/vertically
- Can set motion_x and motion_y variables for sprites
- Sprites can loop continuously or just once
- If you want to change the way something looks in this new UI,
chances are that you can change it via the Configuration menu.
- Samba/NetBIOS sharing support (read roms from your PC)
- Relax Network Sharing (read roms from your PC)
- Play MP3 or M3U playlists in the background
(Can also read MP3/M3U from across Samba/Relax shares.)
- User definable save directory. If you don't like the default of
E:SAVESZ26X you can change it via the Z26X.INI file
- Take in-game screenshots and display them on the game selection list
- New UI feature - auto-screenshot capture mode. When enabled, the emu
will start taking screenshots at a user-defined interval. Useful for
ripping sprites/animation.
- Graphics filters :
+ 2xSai
+ Super 2xSai
+ Eagle
+ Super Eagle
+ SuperScale
+ AdvanceMame 2x
+ Simple 2x
+ 2xSai Scanline
+ Super 2xSai Scanline
+ Eagle Scanline
+ Super Eagle Scanline
+ SuperScale Scanline
- Record/Playback feature - record your gameplay in the emu and then
play it back again. Record up to 10 minutes of gameplay.
- Every single in-game command is fully customizable on any of the
four joypad controllers.
- Map any emulator or UI command to a single button or a combination of
two buttons. (e.g. RTrigger+LTrigger = Save State)
- Autofire capabilities for any emulator button on any controller
- One-button combos (define a series of emulator commands to be played
back when you press a user-definable XBox controller combination.)
(E.g. Press RTrigger+LTrigger to execute the command string
A,B,A,B,Up,Down,Left,Right)
- Traverse any directory on any drive ( Continue selecting the parent
directory entry on the file selection list to get the drive selection
list. Selectable drives are C, D, E, F, R, X, Y, Z, and SMB.
R is the CDROM drive. SMB is the samba share you have defined in your
Z26X.ini file.) Press Y from any file-listing screen to go up one
directory level.
- All UI commands (save state, load state, screenshot, etc) can be
invoked from the Options/Pause menu as well as in-game via your
customized joypad mappings.
- Can be invoked from a command-line to directly run a game from a front-end
or dashboard and bypass the user-selection screens. (Only if the frontend
or dashboard supports this feature.)
- Can return to the launching program *if* the launching program supports this
feature. For example, if the custom-launch routines are incorporated into
a new frontend, that frontend could launch Z26X and when you exit
Z26X, that frontend can be automatically reloaded.
XPort
http://xport.xbox-scene.com/[/color]
