0
Atari to Pc
4 replies to this topic
#1 gonzo90017 OFFLINE
gonzo90017
    Combat Commando
  • 7 posts
Posted Mon Sep 1, 2003 1:38 PM
Can anyone tell me if there is any way to make Atari Joysticks to work on your PC. Has anyone ever tried it?
#2 CPUWIZ OFFLINE
CPUWIZ
    Rarity 11
  • 26,327 posts
  • Cartridge Recycler
Posted Mon Sep 1, 2003 1:46 PM
This is one of the many circuits you can find if you use google. ;)
#3 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 20,458 posts
Posted Mon Sep 1, 2003 4:07 PM
Even easier is to hack a PC gamepad and solder wires from a 9-pin connector onto it's foil. Since the pad uses independant wiring for the fire buttons, you would need to add a switch between the two if you wish to be able to use the pad as well.
In the diagram, the grey lines are the original gamepad traces. Solder the wires as shown...and wire the optional switch (white box) as shown. Cut the trace where the purple line is shown. Then just plug a standard joystick into the 9-pin connecter.
#4 gonzo90017 OFFLINE
gonzo90017
    Combat Commando
  • 7 posts
Posted Mon Sep 1, 2003 5:20 PM
Okay here's the tough one. What about a Trackball Controller? Is there anyway to hook it up to my PC. Would the above schematics apply to it. :?
#5 Eckhard Stolberg OFFLINE
Eckhard Stolberg
    Dragonstomper
  • 882 posts
Posted Sat Sep 6, 2003 8:04 AM
You should be able to use the 2600 Trakball in joystick mode. But using the Trakball in Trakball mode won't be possible, because it generates a code sequence where for example left and right would be pushed at the same time, which is something that those adapters don't support. Also the Trakball would be sending new codes more often than the joysticks on the PC could be read anyway.
Ciao, Eckhard Stolberg
