0
tv/console switch
6 replies to this topic
#1 brett6400 OFFLINE
brett6400
    Chopper Commander
  • 112 posts
Posted Sat Nov 8, 2003 12:13 AM
Hi everyone. I want to hook up my 2600 to my new TV. I know I could do it with the good old tv/console RF switch and RF adapter, but is there a hardware unit to use the video in plugs instead of the coaxial cable adapter?? thanks!
#2 CPUWIZ OFFLINE
CPUWIZ
    Rarity 11
  • 26,327 posts
  • Cartridge Recycler
Posted Sat Nov 8, 2003 12:16 AM
If I understand you correctly, this is the kind of thing you're looking for. :)
http://mcm.newark.co....jsp?id=33-2060
#3 brett6400 OFFLINE
brett6400
    Chopper Commander
  • 112 posts
Posted Sat Nov 8, 2003 12:21 AM
yes, exactly. :) see, i knew i'd get a fast response on atariage.
but $45 for it?? geez. maybe i'll stick with the old tv/console switch.
any thoughts on this issue guys? what do atari agers use? :ponder:
#4 bjk7382 OFFLINE
bjk7382
  • 4,551 posts
Posted Sat Nov 8, 2003 12:25 AM
If you don't want to spend the money on that little box, a second vcr hooked up will do the same exact thing. I use a second vcr and have the coaxial atari going in to it and then there are video/audio outs to hook to the other vcr that I use normally. Then all you have to do is put it on channel F-1 (on mine, Aux on others) and no need to get up to switch the tv box. I have a 75 ohm coaxial switch for switching between the atari systems that I have hooked up.
I can also video tape my games really easy to send into Twin Galaxies. And it doesnt cost anything, except a little more space than that little demodulator.
#5 brett6400 OFFLINE
brett6400
    Chopper Commander
  • 112 posts
Posted Sat Nov 8, 2003 12:42 AM
i also found an 'rf modulator' at radio shack, although i'm not sure if it's bi-directional.
well, maybe i can find an engineering friend to solder one up for me... :D
thanks for the tip on the second vcr, bjk. that sounds easy enough.
#6 Ian Primus OFFLINE
Ian Primus
    Dragonstomper
  • 590 posts
Posted Sat Nov 8, 2003 5:49 AM
You can also modify the Atari to output composite video and audio. There are several different mods floating around on the 'net, ranging from crudely tieing a bunch of signals together (not good) to a very nice circuit with a CD4050. Check the FAQ for more information. Also, there are several running threads here on AtariAge.
Ian Primus
ian_primus@yahoo.com
#7 Muddawg OFFLINE
Muddawg
    Space Invader
  • 41 posts
Posted Mon Nov 10, 2003 6:05 PM
I dont think i will mod my current playing Atari, I'ce had it for four years and i just wouldn't want to risk sodiering in a AV out thingy. But if i get anotehr one cheap i'll think about it :D
