0
Dead Telegames II
7 replies to this topic
#1 Esc OFFLINE
Esc
    Moonsweeper
  • 369 posts
Posted Sun Dec 7, 2003 9:27 PM
I'm getting 8V output, 5V input on the voltage regulator. Is there anything else I can check to see what is wrong with this Telegames II unit (Atari 2800 clone)
I'm getting no output on Channel 2/3, the Telegames II is receiving power OK (LED's light up)
#2 CPUWIZ OFFLINE
CPUWIZ
    Rarity 11
  • 26,327 posts
  • Cartridge Recycler
Posted Sun Dec 7, 2003 9:33 PM
One dirty contact inside the cart slot will bring down the whole machine, check that first. :)
#3 Esc OFFLINE
Esc
    Moonsweeper
  • 369 posts
Posted Sun Dec 7, 2003 9:41 PM
Whats the best way to clean this? I don't think the cover of the cart slot can be removed easily, can it?
#4 Susuwatari OFFLINE
Susuwatari
  • 2,701 posts
Posted Mon Dec 8, 2003 11:50 AM
8v output, 5v input? I think you got that backward or your Teglegames is fried. Input is pin 1 of the regulator (left pin when looking at the front of the regulator), ground is middle pin and output is right pin (pin 3)
#5 Esc OFFLINE
Esc
    Moonsweeper
  • 369 posts
Posted Mon Dec 8, 2003 12:13 PM
yeah I had that backwards, its 8 Volt Input, 5 Volt output
#6 Esc OFFLINE
Esc
    Moonsweeper
  • 369 posts
Posted Sat Dec 27, 2003 4:37 PM
I can check the cart slot contacts, what values are expected with the voltmeter? Most were 3.5V and one or two 5V, some were 0.01V and 0.02 volts..not sure if that is correct
#7 Susuwatari OFFLINE
Susuwatari
  • 2,701 posts
Posted Sat Dec 27, 2003 10:16 PM
Ripped from the 2600 FAQ:
                        Top
 D3   D4   D5   D6   D7   A12  A10  A11  A9   A8  +5V   SGND
--1- --2- --3- --4- --5- --6- --7- --8- --9- -10- -11- -12-
 GND  D2   D1   D0   A0   A1   A2   A3   A4   A5   A6   A7
                        Bottom
The top right and bottom left pin are ground and should read 0v or near 0v. The second pin fromk the right on the top is +5. The rest are used for data and without cart, all the remaining lines would float.
Since you'r egettintg +5v, you can rule out power supply issue. All you need left is to rule out dirty cart port, bad CPU, bad TIA, bad RF cable, and bad RF modulator.
It may be simplier to grab a second 2600 and swap the CPU, RIOT, and TIA to rule out those chips. Nearly all 2600 I've seen uses socketed chips (maybe 1 in 10 are soldered in place)
#8 Esc OFFLINE
Esc
    Moonsweeper
  • 369 posts
Posted Wed Dec 31, 2003 12:23 AM
well i'm a couple of minutes away of ditching this thing. It gives me all the correct values in the cart slot. I tried cleaning the cart slot , but no change. I also changed the RF cord, no difference. I would like to try replacing the chips but the only other console I have is a 7800, and I'm not about to desolder any chips off that to test out the Sears Telegames II.
I'll see if I can pick up a 2600 cheap and rip the chips out of it, or if anyone has some spare chips they'd like to sell please leave me a message.
