Since I wouldn't be able to do anything with my planned 8K multicart until I get those NAND gate, I decided to look elsewhere. O^2 was the first thing that popped in my vision and since there's no documentatuion on such multicart, I'd thought I'd tackle this one. There are reference to a multicart but it seems like vaporware on the internet.
It was like pulling my teeth just to get *any* technicial docs on O^2. And the best I got was the cart pinout so I had to trace to the chip and find what pin are for what. To my surprise, O^2 cart is nearly 100% compatible with EPROM pins. Just 2 minor differences plus a change with EPROM's VCC pin. Actually I shouldn't be surprised at all, O^2 AV mod was insanely easy as well as controller port mod to make it compatible with 2600 controller.
I haven't built a multicart so no guarrantee it'd work. it is just a theory that looks good on paper.
There are 2 basic ^2 cart design: 2K and 4K. 2K doesn't have any P11 line and adding a wire from the cart connector to the EPROM could be messy so try for the 4K cart. No 8K cart was commercially made so you can ignore the need for P10 line.
I'm going to use 2Mbit EPROM for reference (since the *entire* O^2 ROM library can fit). You can use 1Mbit EPROM but only about 2/3 of all O^R ROM could fit. Desolder and remove the old chip. You could install a socket if you want. Make note of where the chip's notch was. The notch of the EPROM (or socket) is on the same side of the PCB as the original chip but pin 1 doesn't go in pin 1. Pin 5 of the EPROM goes in hole 1 of the PCB.
Lift pin 22 of the EPROM (or socket) and connect that to ground (hole of pin 12 on PCB) Lift pin 25 of the EPROM and add a jumper to hole of 18.
Lift pin 28 of the EPROM, that will go to DIP switch 2. Connect pin 31 and 32 to hole of 24 (VCC). 29 goes to switch #3 and 30 to switch 6 (NC on 1Mbit EPROM)
pin 4 of EPROM to switch #1, 3 to SW 4, and 2 to SW 5. Finally, pin 1 of the EPROM should be grounded I(you know where it is?)
like with Atari 2K/4K multicart, you'll need to double up all 2K ROM (use copy /b game.bin+game.bin game4k.bin in DOS box) Then combine all the 4K ROMs in the order you want on EPROM.
I'll post later when I get around to building it. I'd appreciate feedback from O^2 experts (especially if P11 line behaves like normal address line or not)
Future plan could include menu driven selection but I have no experience on programming O^2. One plausiable way is to use the unused P10 line to send clock pulse to a binary counter (like a 7493 4 bit binary) and binary counter could be connected to the higher address line of the EPROM. Then restart the machine so it'd behave as if you just inserted the game cart. I don't know how this can be done since there's no software reset (reset button is not software controlled)
