0
Whats the difference?
7 replies to this topic
#1 Rocko OFFLINE
Rocko
  • 2,142 posts
Posted Tue Dec 30, 2003 11:02 PM
What is the difference between the:
Turbo Grafx 16
Turbo Duo
PC Engine
Super Grafx
#2 Ze_ro OFFLINE
Ze_ro
  • 8,511 posts
  • Welcome Back!
Posted Tue Dec 30, 2003 11:08 PM
Turbo Grafx 16: Well, lets consider this the "basic" system...
Turbo Duo: A Turbo Grafx 16 that has a built-in CD-Rom drive. To get the equivalent system, you'd have to buy a TG16, a Turbo CD, and a Super System 2.0 card.
PC Engine: Japanese version of the TG16. PCE/TG16 games can be played on the opposite system with an adaptor.
Super Grafx: A slightly improved version of the PC Engine. It plays PC Engine games without trouble, but there were only 5 or so games that actually took advantage of the extra abilities of the Super Grafx. It's a cartridge-based system, but I think you can hook it up a CD-Rom drive with some work.
--Zero
#3 JB OFFLINE
JB
  • 9,211 posts
  • With Stereo-Of-The-Art-Sound
Posted Tue Dec 30, 2003 11:34 PM
I thought the Duo came with System 3, which also meant it had more RAM.
Quote
Actually, it's 1 way only. As I understand it, TG16 games are written to detect a hardware diffrence between the TG16 and PCEngine and won't work on the PCE, though PCE games work on the TG16.
Quote
--Zero
It CAN attach to a CD-ROM, but it needs an adapter for the older model drive.
And the only hardware upgrade to the SuperGrafx was another layer in the graphics hardware.
And there's a 6th game. Darius Plus had a SuperGrafx mode as well as a PCE mode.
#4 Vic George 2K3 OFFLINE
Vic George 2K3
  • 5,078 posts
  • GNAP ATTACK!!!
Posted Tue Dec 30, 2003 11:39 PM
Just find it weird that the Japanese name for the TurboGrafx was the PC Engine, but the manufacturers would call their Japanese-only system the Super Grafx.
#5 sku_u OFFLINE
sku_u
  • 13,984 posts
Posted Tue Dec 30, 2003 11:52 PM
Out of all those systems, which one is the best to own in terms of greatest overall compatability?
#6 JB OFFLINE
JB
  • 9,211 posts
Posted Wed Dec 31, 2003 12:53 AM
Only a SuperGrafx with CD-ROM(and appropriate boot disks) can play every game.
But is missing 5 games and an enhanced version of a 6th really that critical?
The Duo is nice for the all in one aspect. It'd be what I went for.
#7 Susuwatari OFFLINE
Susuwatari
  • 2,701 posts
Posted Wed Dec 31, 2003 11:40 AM
Actually as I understand, TG-16 and PCE cart slot differs only with 8 data line being flipped over. If you flip the 8 lines, you can play either games. Adapter exists with that 8 lines flipped or you could look for 8PDT switch and modify your TG-16/Duo/PCE/SG to take both USA and Japanese card without the adapter. Here's a copy of the old FAQ:
        How to put a PC Engine / TurboGrafx switch in your TurboGrafx
By Karl Stenerud (mock@res.com) 29-Jun-96
Modified by Earnest Rymer (rymerel@valleyint.com) 12-Feb-2000
This document must be viewed in a monospaced font, 80 column format.
DISCLAIMER:
I take no responsibility for any damages incurred through the use of this
document or its contents.  Use at your own risk.
       MAKE SURE YOU READ THE ENTIRE DOCUMENT THROUGH BEFORE STARTING!
            YOU WILL BE ALTERING CONNECTIONS WITHIN YOUR MACHINE!
INTRODUCTION:
A few years ago, a friend of mine gave me his PC Engine.  I soon became
obsessed with the thing and gradually acquired a Turbo Duo and a TurboExpress
(as well as tonnes of games).  The only problem was that all my games were
the Japanese HuCards, which didn't work in the American systems without some
sort of converter unit, which I promptly bought.
I soon learned to hate the thing since it would crash my game at the slightest
nudge of the game converter (Very annoying since I liked to use my Turbo
Express).  I soon became so frustrated that I took apart the game converter,
found out what it did, and made a switch that would do it instead.
MUCH BETTER!
Anyway, if you hate the TV Game converter thingy for playing Japanese
HuCards, and you know a little about electronics, this text is for you!
THE THEORY:
In order to play import games, eight leads from the HuCard to the console must
be rerouted like this:
                          /      #     #  HuCard socket unit
         front of machine ||      #     #  (top view)
                                  ||||||| <- pins
                  10                  20                  30              38
                         | | |        X    | | |
                  10                  20                  30              38
* these pins go straight through
pins: 16 -> 24
      17 -> 23
      18 -> 22
      19 -> 20
      20 -> 19
      22 -> 18
      23 -> 17
      24 -> 16
The pin swapping is symmetrical.  However, pin 21 is not rerouted.
WHAT YOU NEED:
- A TurboGrafx, Duo, or Express (duh!)
- gamebit or equivalent
- soldering iron and light-gauge solder
- hacksaw blade / X-acto knife (for cutting notch in case)
- wire cutters
- 16-conductor ribbon cable
- an eight-pole, double-throw switch
- epoxy
- other various tools (tweezers, toothpicks, you'll figure it out!)
  The switch should look something like this on the bottom:
          1      2      3      4          1      2      3      4
        a b c  a b c  a b c  a b c   /   a b c  a b c  a b c  a b c
          5      6      7      8          5      6      7      8
        There are eight individual      When you throw the switch,
        switches                     /   eight contacts change the
                                        eight switches
  NOTE: This kind of switch is hard to find (Especially one small enough
  to fit in the Express).  I found mine by using the part locator at
  www.e-switch.com. The part number is EG-8202.
BEFORE YOU BEGIN:
1. Open up your machine.  Unfortunately, your machine likely has some strange
   screws in it.  Someone on the Turbo Mailing List said they know where to get
   the screw bits.  You can make your own tool by cutting a notch in the end of
   a blade-type screwdriver with a hacksaw.
2. Locate the HuCard socket unit.
3. Find a nice place to put a switch.  On the Express, I found that the best
   place is at the bottom of the machine, although I had to remove the COM
   port.  Another list member went into the battery compartment.  On the
   TurboGrafx, I mounted it on the right side of the machine.
4. Decide how much wire you'll need.  You'll have 16 wires running from
   wherever you decide to put the switch to the HuCard socket in parallel.
   This is where ribbon cable comes in real handy.  I just hacked up an old
   SCSI cable.
5. Test-fit everything first.  I have found that it's better to do the case-
   cutting first, because your hands (and likely your brain!) will become
   fatigued from all the electronic work.  This way, you'll be doing the
   cosmetic work when you are at your most patient.
6. I strongly suggest you find out where to get a replacement HuCard socket
   unit in case something goes wrong.
LET'S HACK!:
1. Get your switch and solder small pieces of insulated wire, crossing
   "a" on one switch and "c" on the opposite switch like so:
                         1       2       3       4
                         5       6       7       8
   NOTE: the crossing wires must NOT be connected to each other!
*** STEP 2 IS THE POINT OF NO RETURN! ***
2. Desolder pins 16, 17, 18, 19, 20, 22, 23, 24 (NOT 21!) from the PC board
   (see above, "THE THEORY").  Straighten the pin out and cut it at a
   convenient length for you to solder on the new wiring.
3. Using the soldering iron and solder, connect the insulated wire from the
   switch to the pins of the HuCard socket unit like so:
                 1            2            3            4
                16l 16h      17l 17h      18l 18h      19l 19h
                24l 24h      23l 23h      22l 22h      20l 20h
                 5            6            7            8
   where "l" ("low") is on the PC board and "h" ("high") is on the pins of
   ie. terminal "b" of switch 1 connects to 16l, which is pin 16 on the PC
       board.
       terminal "c" of switch 1 connects to 16h, which is pin 16 on the
       HuCard socket.
                         pins
                "high" -> ++--########   HuCard socket unit
                          ||  ########   (side view)
                "low" -> -------------
                           pcboard
4. Connect all vital components and test the machine.  I recommend giving
   everything a real good wiggle to ensure a proper connection.  If
   something is going to pop off, you want it to happen now, and not after
   the epoxy's dry!
5. Mount the switch.  I used epoxy, but you'd be surprised how well that blue
   tack stuff works in a pinch!  I recommend scoring the surfaces of the
   switch and the TurboGrafx before gluing them.  This will help the epoxy
   set.
Congrats! You now have a PC Engine / TurboGrafx switch!
#8 Ze_ro OFFLINE
Ze_ro
  • 8,511 posts
  • Welcome Back!
Posted Wed Dec 31, 2003 11:42 AM
You may be right... I'm not up on all the TG16 stuff.
Well, ideally you'd have to get a Super Grafx with a CD-Rom (and the necessary adaptor), as well as the "Arcade card"... but that would be a huge pain in the ass to collect, and it would be a total Frankensystem (and is the Super Grafx also locked out from playing North American TG16 games?).
I'd say just get a TurboDuo. Every North American release should work fine, and you can pick up an adaptor to play the Japanese releases. However, there's a "Super System 3.0" card out there that might be needed by some games (Was this needed for any NA releases? or just Japanese?), and there are a handful of Japanese games that require the Arcade Card...
--Zero
