0
Help cleaning a 2600 heavy sixer itself...
3 replies to this topic
#1 HurricaneAndrew OFFLINE
HurricaneAndrew
    Combat Commando
  • 3 posts
Posted Fri Jan 9, 2004 8:31 AM
Here's my issue. The outside looks great. I took the unit apart (an original Heavy Sixer, manufactured 1/14/81, according to an ancient piece of paper taped to the inside) and was able to get all the dust and grime off of and out of the unit. I have a couple of remaining issues, however:
1) A couple of the switches (mainly the game select switch) are very sticky. I cleaned as much as I dared around them with canned air, and just a touch of rubbing alchohol on a q-tip. What else can I do to improve the action of the switches?
2) There is an area on the side of my TV screen, approx. 5-6 inches long and maybe 1/4 inch wide running down the left side of every game. It doesn't affect game play, it's just annoying. I'm assuming it's one of two things: I have a new TV-Game adapter purchased at Radio Shack to connect the unit to the TV via the "new" standard RF connection. Or, the contacts on the unit itself need to be cleaned. If the latter, how can I clean this area? That portion of the system seems pretty solid, and other than cleaning around the outside, there does not appear to be any way to really clean the inside where the cartridges go.
Any thoughts?
#2 joeybastard OFFLINE
joeybastard
    The hottest thing from the North to come out of the South
  • 12,219 posts
  • Lover of All American Burgers
Posted Fri Jan 9, 2004 11:10 AM
Welcome to AA :)
1. Get a can of CRC Electronics Cleaner (or another brand I just like CRC) and spray it into any gaps in the switch cover. Just a little and move the switch up and down a few times. If it still seems sticky, repeat. This stuff evaporates so don't worry if you have little puddle when you spray it, just give it a minute or twoto dry before plugging it in.
2. I'm guessing that you're referring to something that happens in many 2600 games and sometimes appears as thin black lines. There's nothing wrong, that's the way the game is.
#3 joeybastard OFFLINE
joeybastard
  • 12,219 posts
Posted Fri Jan 9, 2004 11:15 AM
This Atlantis screenshot shows some of the lines I'm talking about, is that what you're getting?
#4 HurricaneAndrew OFFLINE
HurricaneAndrew
    Combat Commando
  • 3 posts
Posted Fri Jan 9, 2004 12:56 PM
Very similar, but there's more of 'em. That's certainly the general appearance and location though. Guess I'll live with it. Like I said, it's not impacting game play, so I guess it's just aging a little less gracefully than I am :-)
Thanks for the tip regarding issue #1, I'll give it a go tonight.
