0
Question re: CV power supply
12 replies to this topic
#1 Zeus OFFLINE
Zeus
  • 1,769 posts
Posted Fri Jan 9, 2004 4:19 PM
Does the Colecovision have a proprietary A/C adaptor or can any generic one will do? What is the voltage?
#2 CPUWIZ OFFLINE
CPUWIZ
    Rarity 11
  • 26,327 posts
  • Cartridge Recycler
Posted Fri Jan 9, 2004 4:30 PM
4     1
  3 2
Pinout
1: +5V (white)
2: -5V (blue)
3: +12V (red)
4: GND (black)
Totally non-standard.
#3 Zeus OFFLINE
Zeus
  • 1,769 posts
Posted Fri Jan 9, 2004 4:36 PM
Thanks!
#4 joeybastard OFFLINE
joeybastard
    The hottest thing from the North to come out of the South
  • 12,219 posts
  • Lover of All American Burgers
Posted Fri Jan 9, 2004 7:07 PM
Hey Zeus I have an extra that I think is still good if you want me to check it out. I'm sure we can make an agreeable trade for it. :)
#5 nesfanboy86 OFFLINE
nesfanboy86
    Star Raider
  • 53 posts
Posted Fri Jan 9, 2004 8:05 PM
the thing is huge and takes up my whole outlet and it heats up like a bitch!
#6 VidGameKing OFFLINE
VidGameKing
  • 2,208 posts
  • Thumbing away on my iPhone!
Posted Sat Jan 10, 2004 11:09 AM
CPUWIZ said:
4     1
  3 2
Pinout
1: +5V (white)
2: -5V (blue)
3: +12V (red)
4: GND (black)
you could probably use a PC power supply for that. it makes +5 -5 +12 -12
#7 CPUWIZ OFFLINE
CPUWIZ
    Rarity 11
  • 26,327 posts
Posted Sat Jan 10, 2004 1:35 PM
VidGameKing said:
CPUWIZ said:
4     1
  3 2
Pinout
1: +5V (white)
2: -5V (blue)
3: +12V (red)
4: GND (black)
Yes, an AT power supply to be precise.
#8 VidGameKing OFFLINE
VidGameKing
  • 2,208 posts
Posted Sat Jan 10, 2004 1:56 PM
there would be no way to turn an ATX power supply on without a motherboard!!!! so yes, of course an AT power supply would work. like those found in PC computers older than Pentium 2. any K-2, K-3, K-4s Pentiums, Pentium Pro ect... 486, 386, 286, 8088, 8086 ect...
#9 Ze_ro OFFLINE
Ze_ro
  • 8,511 posts
  • Welcome Back!
Posted Sat Jan 10, 2004 2:06 PM
The wall-mounted brick is pretty awful, but there's also a version that's designed to sit on the floor, with a cord seperating it from the outlet. I wish mode systems did that actually, since all my power bars get blocked up by one or two power supplies :x
--Zero
#10 Mitch OFFLINE
Mitch
  • 5,769 posts
  • 7800 Guy
Posted Sat Jan 10, 2004 2:18 PM
Actually, there is a way to turn on an ATX power supply. You just need to ground pin 14 (should be the green wire) and it will turn on. Make sure you have a load on it before you turn it on though or you may have problems.
Mitch
#11 VidGameKing OFFLINE
VidGameKing
  • 2,208 posts
Posted Sat Jan 10, 2004 3:23 PM
okay you can turn it on but you'll need to have that load. A standard AT P/S needs no load to work properly.
#12 Susuwatari OFFLINE
Susuwatari
  • 2,701 posts
Posted Sat Jan 10, 2004 3:24 PM
Mitch
That's right, green is power on for ATX power supplies. And I could suggest a 10 ohms, 10 watts resistor on the +5v line to keep the power supply stable.
#13 desiv OFFLINE
desiv
  • 1,065 posts
Posted Sat Jan 10, 2004 7:59 PM
Yeah, but you will have that load.. The Colecovision.. :-)
Of course, I agree.. I used an AT for my Adam.. They're easy to acquire.
1 thing to watch for tho, is the on/off switch. My AT supply had its on/off switch at the end of about 10" of cable, so I had to reroute and mount it in the AT PSU case. (Well, I didn't HAVE to, but I didn't like the concept of the on/off switch just dangling.. hey..
(Dangerous.. Thought happening.. I'd run if I were you...)
I wonder if I can fit the AT PSU inside my Adam. In my spare tape drive bay or where the card slots are... hmmmm.. Then I could just run the switch to the Adam front panel...
Hmmm...
This is maybe where an mini-ATX supply might work better...
Great.. Now I have a headache.. :-)
desiv
