0
Assembly Language Programming - Lesson 7 - State Machines
1 reply to this topic
#1 Robert M OFFLINE
Robert M
  • 1,481 posts
  • Rootbeer!
Posted Fri Nov 12, 2004 7:11 PM
Assembly Language Programming - Lesson 7 - State Machines:
The next topic I want to raise is the idea of a state machine.
All digital computers are state machines.  Therefore the Atari
2600 is a state machine.  It will be easier to program a
computer/the-VCS if you understand the basic principles of state
machines.
Here is a link to website that I want to borrow the definition
for a state machine from:
http://www.nist.gov/dads/HTML/finiteStateMachine.html
Here is the basic definition from that website:
"finite state machine
Definition: A model of computation consisting of a set of
states, a start state, an input alphabet, and a transition
function that maps input symbols and current states to a next
state. Computation begins in the start state with an input
string. It changes to new states depending on the transition
function. There are many variants, for instance, machines having
actions (outputs) associated with transitions (Mealy machine) or
states (Moore machine), multiple start states, transitions
conditioned on no input symbol (a null) or more than one
transition for a given symbol and state (nondeterministic finite
state machine), one or more states designated as accepting
states (recognizer), etc.  Also known as finite state automaton."
Lets break this definition down and look at each part:
"A model of computation consisting of a set of states" - This is
just fancy talk saying that you can do all the things a computer
can do on a piece of paper.  You can model a computer on paper,
or maybe a computer models work done on a piece of paper.  Its
one of those twilight-zone things.   The computer and the model
of the computer are equivalent.  The only difference is how long
it takes for each to complete the same job. Every computer has a
set of special circuits called registers.   Registers hold bits
of information, 1's and 0's.   All of the register bits in a
computer together form the "state" of the computer.  In future
lessons, I will introduce you to the registers in the Atari VCS,
but for now all you need to know is that they are there and they
are apart from your program.
"a start state" -  When you turn on a computer, electricity
floods into the circuits of the machine.   At that point all the
registers are scrambled and their state is unknown.   Luckily,
the designers of the hardware included reset circuits that force
at least some of the registers into a known state.  Just enough
of a known state so that the computer can start running a
program, your program.  When you turn on a VCS, the system
powers up to its start state.  It goes to a specific place in
the memory of the plugged in cartridge and begins executing the
program it finds there.
"an input alphabet" - The input alphabet is Assembly language
code!  It also includes all the switches and input ports on the
machine to a lesser degree.   You write a program using the
"alphabet" of assembly language instructions that the
microprocessor in the VCS is made to process.
"and a transition function that maps input symbols and current
states to a next state" - The transition function is implemented
by circuits in the machine that fetch the instructions
(alphabet) of the program and update the registers (state) of
the VCS based on what that input symbol (Assembly code
instruction) is.  When you learn to program in assembly language
what you are really learning is the transition function.   When
you know the transition function of the VCS (state machine),
then you will be able to string the instructions of the
computer's alphabet into programs (input string) that generate
the series of states that result in a video game.
"Computation begins in the start state with an input string"  -
Computation is what computers do.;)  I already defined the
start state.   The input string is your program code and the
variables you use to store changing information about the game.
Now we get to a real mind bender.  Your program generates a
sequence of states within the VCS that render all the  graphics
and audio and player control that make up your game.  That
sequence is a subset of ALL THE POSSIBLE sequences of states
that a VCS can do.   In a way, your programming a VCS is like a
sculptor carving a statue from a large stone block.   The
sculptor cuts away the excess rock and leaves behind the desired
shape of stone.   Likewise, as a programmer you will cut away
all the excess sequences of states that the VCS can perform and
leave behind only the sequences that form your game.
So from that reasoning we can see that it may make sense to look
at a video game as a state machine.  Or really as a series of
state machines.    Once you get down into the details of a
program you will find that there is no way your mind can keep
track of all possible sequences of states, so you will need to
break the program down into manageable problems (small sets of
simple states)  that you can understand.  A very common
programming approach is called top down design, and I think it
is a good place to start as a beginning programmer.   You take
the large problem of a program (the top) and break it down
repeatedly into smaller and smaller chuncks.   Eventually those
chunks become so small that they are individual Assembly
language instructions.  Lets take a look at a common video game
as a high-level state machine.    Let's look at Combat. Combat
is a very common game so its easy to use as a reference.   You
can even plug it in an refer to the game as you read my
explanation.
As we learned above, all state machines have an initial state,
and all video games are state machines, so Combat is a state
machine and it has an initial state.   Lets call that intial
state RESET.
In the reset state the program sets all of the registers in the
VCS to a known state, then it transistions the ATTRACT state.
             (done)
    RESET  ---------->  ATTRACT
(initial state)
In the ATTRACT state the Combat game draws the playfield with
different colors than those used during play.  It waits for the
user to push the Select, Reset, or difficulty switches.   If the
difficulty switches are changed, the program updates the state
of machine (not the game, the machine we are looking at Combat
from a simplfied/high level), and remains the ATTRACT game
state.   Likewise if the select button is pressed the machine
state is updated to show a new game option, but the game stays
in ATTRACT mode.   The only way to leave attract mode is to
press Reset.   Pressing reset transitions the game to PLAY mode.
            (done)                 (Reset)
    RESET  ---------->  ATTRACT  ---------> PLAY
In the PLAY game state the game timer begins counting down, and
the players controls are read and used to update the machine
state to reflect the game play.   The PLAY state is exited if
the player pushes Select, or the game timer runs out.  In either
case it returns to the ATTRACT mode.
Combat:
           (task done)            (Reset)
(initial state)            ^                  |
                           |  (timer/select)  |
This is very simple state model for Combat.  Each of these
high-level states can be broken down into several smaller more
informative states.   Eventually, breaking the model down to
enough detail you reach the sequence of states that are the
individual Assembly language instructions in the Combat program.
 As a programmer you will want to break the large problem of a
video game into smaller problems that you can reasonably tackle
one at a time until the complete game is done.
Exercise:
Pick an Atari cartridge and create a high-level state diagram
for the game as I did above for Combat.   Provide as many states
as you feel like doing.   Post your diagram to this thread so
others can see it.   Its a pain to make diagrams in ASCII as I
did, so you may want to draw them in a painting program and then
post the picture in this thread.
#2 Rob Mitchell OFFLINE
Rob Mitchell
  • 2,657 posts
Posted Wed Nov 17, 2004 9:46 AM
This sounds pretty intuitive.
I remember a 1970s interview with Nolan Bushnell who stated that using a joystick or paddle to interact with the computer via the TV screen was a low level of programming.
Rob Mitchell, Atlanta, GA
