0
How to save sceenshots of Atari 2600 games
9 replies to this topic
#1 Atari Charles OFFLINE
Atari Charles
  • 2,177 posts
Posted Sat Nov 13, 2004 4:37 PM
How do I save a screenshot of an Atari 2600 game(when using an emulator on a computer)?
Is there a specific program I have to use or is it a command within a specific emulator?
Thanks
#2 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 20,458 posts
Posted Sat Nov 13, 2004 5:25 PM
In Z26, you press the = key. The snapshot will be saved in the current directory as a PCX file (default)...but you can add a command-line tag to save it as .BMP
#3 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!
  • 16,745 posts
  • Always left from right here!
Posted Sat Nov 13, 2004 6:38 PM
Sometimes RTFM really helps. ;)
#4 Atari Charles OFFLINE
Atari Charles
  • 2,177 posts
Posted Sat Nov 13, 2004 7:46 PM
Thanks. Yes I am going to have to RTFM. :D
#5 stephena OFFLINE
stephena
  • 1,969 posts
  • Stella maintainer
Posted Sun Nov 14, 2004 9:40 AM
In Stella, use F12. By default, it will save a PNG image to the same directory (in Windows) or the $HOME directory (in Linux). There are commandline options to change where the snapshot is saved or how it's named.
Steve
#6 bigfriendly OFFLINE
bigfriendly
    Space Invader
  • 11 posts
Posted Thu Nov 17, 2011 1:51 PM
Steve
I was wanting to post some game pics on my wordpress blog. When I press F12 while using Stella it says that the screen has been saved. What I don't understand is how to locate it in Windows??? I don't understand how to follow the instructions above. Could somebody explain this so that a person who bumbles his way around on a PC can understand it:)
Thanks
#7 stephena OFFLINE
stephena
  • 1,969 posts
  • Stella maintainer
Posted Thu Nov 17, 2011 6:09 PM
Steve
Thanks
First of all, a lot of things have changed since 2004 :)
Go to Options -> Config Files -> Snapshot path. This shows where snapshots are saved. By default it stores in ~/Application Data/Stella somewhere, which admittedly is a bad choice since that folder is hidden in Windows Explorer. Click the button to select a new directory (perhaps your desktop folder) and then try taking new snapshots. Then they should appear in the location you specified.
#8 bigfriendly OFFLINE
bigfriendly
    Space Invader
  • 11 posts
Posted Thu Nov 17, 2011 8:53 PM
Steve
Thanks for your response to my question. Which options do I go to? I use Mozilla not IE does that make a difference? Sorry if these are dumb questions but I really want to figure this out. I looked at the folders in the Stella program but didn't see anything. Please help:)
#9 stephena OFFLINE
stephena
  • 1,969 posts
  • Stella maintainer
Posted Fri Nov 18, 2011 7:22 AM
Steve
Actually, I was referring to the options within Stella itself. As soon as you start the application, notice that there are four buttons along the bottom. One of them is labeled 'Options'. You click this button, and then another set of buttons appear. From that selection you click 'Config Files'. Finally, yet another UI appears, and you click 'Snapshot path'. This gives you a file browser that looks something like the following:
It won't look exactly like this, since I'm on a Mac right now. Anyway, click the 'Go Up' button to move upwards in the file system (ie, to select parent folders), and double-click on entries in the list to enter folders. When you find the folder you want, click 'Choose'. Then click 'OK' to all the windows that appear.
I would suggest saving the snapshots in your C: drive for now, until you get comfortable with navigating the filesystem. And the next release of Stella will fix this, and choose more appropriate defaults saving snapshots.
#10 bigfriendly OFFLINE
bigfriendly
    Space Invader
  • 11 posts
Posted Sun Nov 20, 2011 12:17 PM
Thanks for your help:) I figured it out and also changed the destination to another folder so I could find the screen shots easier. Thanks again for making the forum a great place
Scott:)
