It sounds like you are talking about the Atari Touchtablet, which is NOT a lightpen, the pen it comes with is merely for use with the tablet which is the part that does the actual input to the computer, you could use a stick if you wanted, instead of the pen it came with. The only thing the pen has is a button on it that you can use, but there are also 2 buttons on the touchtablet itself which also do the same thing (for right or left handed people). I do think that Atari DID have a lightpen too, but it doesn't come with a tablet, lightpens are used DIRECTLY on the TV or monitor. What Panda Racer needs is software to use with the lightpen he has, and if that lightpen is truely atari compatible, e.g.-works like Atari's own lightpen, then there are quite a few drawing/painting programs that support lightpens for the Atari, but mostly you just have to find some graphic art program ATR files on the net at the usual Atari download sites, and load them up and see if they have an option for use with a lightpen. I know 'Rambrandt' can use all sorts of devices like joysticks, trackballs, tablets, mice and lightpens too. if you do a quick search, I recently (like a week or two ago) posted a zip file with Rambrandt and utilities and documention. I'd suggest downloading this and getting it on disk (generally you will need SIO2PC&A.P.E software to accomplish this) or load it from the PC with SIO2PC cable, plug in the lightpen, choose the input device in Rambrandt for "lightpen" and see if it works. There are other paint programs that will also work with lightpns, but many that will only work with a joystick too, you just have to search until you find a compatible program.
here is the link:
http://www.atariage....showtopic=70489
Edited by Gunstar, Sat Jun 18, 2005 10:50 AM.
