A Puzzle Game
48 replies to this topic
#1 Aaron OFFLINE
Aaron
    Chopper Commander
  • 105 posts
Posted Mon Jul 18, 2005 10:30 PM
For the Mini-Game compo this year I thought I'd do a version of an old calculator game called DStar.
The idea is to collect all the blue rings, but the trick is that you always move in a straight line until you hit something. Also you can alternately control a block to help get around the level. Anyway, play it, it's not that hard to figure out. :)
Fire switches between controlling pac man and the blocker, which you'll need to finish the level (not detected yet).
Posted Image
  • Attached File  astar.zip   1006bytes   180 downloads
#2 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,237 posts
  • begin 644 contest
Posted Mon Jul 18, 2005 11:14 PM
Posted Image
View Post
I like these types of games. Still trying to figure out how to get some of those blocks near the bottom...
How will the score be determined?
#3 Aaron OFFLINE
Aaron
    Chopper Commander
  • 105 posts
Posted Tue Jul 19, 2005 12:01 AM
View Post
Hrm, do people actually care about a score in a game like this? I didn't think it would be meaningful.
#4 djmips OFFLINE
djmips
    Dragonstomper
  • 591 posts
  • scrolling
Posted Tue Jul 19, 2005 12:48 AM
Well, like in Jammed, you can solve it or you can solve it in the minimum number of moves.
Nice game.
Edited by djmips, Tue Jul 19, 2005 12:48 AM.
#5 Zach OFFLINE
Zach
  • 1,477 posts
Posted Tue Jul 19, 2005 1:17 AM
:) That was a fun puzzle. Nice job. It didn't take too long to solve the first level. I trust you will be adding graphics for when Pac-Man faces up or down, or will you do it Todd Frye style?
#6 TMR OFFLINE
TMR
  • 2,312 posts
  • Beeping the horn on the data bus
Posted Tue Jul 19, 2005 6:48 AM
View Post
View Post
Oh goodness yes, it needs scores - that's a large wodge of the replay value right there! In a game like this you can have a score per item, a bonus timer ticking down that gets awarded at the end of a level and a moves counter that gives a few spare to multiply by ten for a second bonus to make sure the scores aren't fixed per level. Running out of time or moves needn't be fatal, although i'd make the timer fatal myself to add a bit of urgency to the proceedings.
i'll have a play of it when i'm at me own computer, i'm at work right now so can't have a game.
#7 Aaron OFFLINE
Aaron
    Chopper Commander
  • 105 posts
Posted Tue Jul 19, 2005 11:36 AM
View Post
Ok, sorry, but I really think urgency in puzzle games is a Bad Thing. If you're looking for that sort of thing, go take the GRE or something. :)
I guess a moves counter would work though...
Yeah, I'm sure that would look better, I just hadn't decided if I ought to keep Pac-Man in the game or not. But since we all know the best way to become popular is to leech off the popularity of others... :roll:
#8 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!
  • 16,745 posts
  • Always left from right here!
Posted Wed Jul 20, 2005 4:57 AM
Agreed. Those games work best if you can take your time.
A moves counter should do. Just let it count backward from the minimum number of moves.
#9 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 16,745 posts
Posted Wed Jul 20, 2005 5:02 AM
I suggest using a marble/ball. That should simplify animation and save a lot of space.
#10 TMR OFFLINE
TMR
  • 2,312 posts
Posted Wed Jul 20, 2005 9:03 AM
Me, i like urgency but that's me... but a bonus timer can still go in, you just don't end the game if it runs out so players who go through the levels faster score more points - it means that, as people learn the game, they get better and get higher scores so there's another facet of replay value innit. =-)
#11 djmips OFFLINE
djmips
    Dragonstomper
  • 591 posts
  • scrolling
Posted Wed Jul 20, 2005 9:37 AM
View Post
You might like Ricochet Robots it is a similarly themed board game, but competitive, with a timer and everyone has to analyze the board at the same time and come in with lowest bid on the number of rebounds before the timer is exhausted.
#12 Aaron OFFLINE
Aaron
    Chopper Commander
  • 105 posts
Posted Fri Jul 22, 2005 11:13 PM
Here's an update. Added a moves counter, an icon for what you're controlling, and some more levels (the one was just hard-coded in before).
I decided to keep Pac-Man in. Or rather, Non-Infringing-Yellow-Pie-Shaped-Man. He just works too well in the role. :)
The problem with that is, I don't know the minimum number. :roll: There are very likely multiple ways to solve each level - just about every time I've placed a ring so far, I've found out there was an easier way to get it than what I had planned.
So it counts up from zero for now. But anyway, here are my "par" counts for the levels so far: 49, 46, 39, 30. I'm sure someone can do better.
#13 supercat OFFLINE
supercat
  • 6,367 posts
Posted Sat Jul 23, 2005 12:04 AM
Very nice. It would be useful, though, if you could add some sort of 'undo' feature. I know multi-level undo isn't likely on a stock 2600, but even a single-level undo would be very handy.
#14 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 16,745 posts
Posted Sat Jul 23, 2005 12:46 AM
Then cheat and write small program which finds the optimal solutions for you. Then you have the numbers. :)
#15 Zach OFFLINE
Zach
  • 1,477 posts
Posted Sat Jul 23, 2005 12:54 AM
View Post
Coincidentally, there is a common search technique you could use called A* (A star). 8)
Edited by Zach, Sat Jul 23, 2005 12:58 AM.
#16 Cybergoth OFFLINE
Cybergoth
  • 8,207 posts
  • This is Sparta!
Posted Sat Jul 23, 2005 5:17 AM
Hi there!
View Post
Personally, I think *not* knowing the "best" solution is probably more fun for the players.
Greetings,
Manuel
#17 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 16,745 posts
Posted Sat Jul 23, 2005 6:07 AM
Really? :?
They wouldn't know the exact solution, only the minimal number of moves. IMO it should be pretty motivating to find the optimal solution and getting awarded by the game somehow then.
Hm, maybe the game shouldn't tell the player before?
#18 Cybergoth OFFLINE
Cybergoth
  • 8,207 posts
  • This is Sparta!
Posted Sat Jul 23, 2005 8:34 AM
Hi there!
Really? :?
Yup. Basically, as long as I haven't figured out the "best" solution, the game is constantly telling me that I *suck* each time I play the level ;)
I rather prefer it that when I improved upon my previous personal best, I can think: YAY I DID IT AGAIN! ;)
Greetings,
Manuel
#19 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 16,745 posts
Posted Sat Jul 23, 2005 8:55 AM
For me it's completely different, I always want to get as close to perfection as possible. :)
#20 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,237 posts
  • begin 644 contest
Posted Sat Jul 23, 2005 2:34 PM
View Post
I can vouch for that... I haven't yet managed to improve on Thomas's code, and believe me, I've tried ;)
#21 supercat OFFLINE
supercat
  • 6,367 posts
Posted Sat Jul 23, 2005 5:37 PM
View Post
For the rightmost ring in the penultimate row, move the block down, right, down, right, down. Then move the slotted hockey puck down and right. For the other one, the block and hockey puck can build out from the left edge near the top until the hockey puck is in the right column, whereupon it can go down.
#22 Albert OFFLINE
Albert
  • 27,238 posts
Posted Sat Jul 23, 2005 5:41 PM
Excellent, another puzzle game for the 2600! The system definitely does not have enough puzzle games (Okie Dokie, Jammed, Crazy Valet, ... ??) and it would seem well suited for them. You have my encouragement to continue development!
As far as telling the player the minimum number of moves required to solve the puzzle, I would much prefer to see that also (just as with Jammed). While I may not be able to solve the puzzle in the minimum number of moves, I'd at least like to know how far off from the target I am! Otherwise I have no way of knowing, unless perhaps the game notified me if I did solve the puzzle perfectly (after the fact). Although I think it should do that anyway, as a reward of sorts. :)
..Al
#23 Aaron OFFLINE
Aaron
    Chopper Commander
  • 105 posts
Posted Sun Jul 24, 2005 11:09 PM
View Post
No problem. :cool:
For now reset works like you'd expect.
View Post
Any good ideas for an algorithm for that? :roll: I don't think brute force would work when dealing with 8^40-something possible moves. Maybe something with flood-fill...
View Post
I thought someone might notice that. :) I don't think it's really (directly) applicable here though, or maybe I'm just being stupid...
View Post
See, I can understand that. It's kind of a downer when you're told up front "this is the best you can ever do".
So I was thinking of instead including par scores that you could potentially beat, but then they would probably be a lot of work to figure out...
#24 djmips OFFLINE
djmips
    Dragonstomper
  • 591 posts
  • scrolling
Posted Mon Jul 25, 2005 1:06 AM
View Post
Although A* is often associated with pathfinding on a map it is more abstractly a graph search which can be tuned to find the shortest path. A colleague used the algorithm to search through a graph for choosing the best strategy for the computer opponent in a turn based strategy game.
Even though you have such a large set of possible moves, pruning will reduce that.
Of course if all else fails, you could try brute force and a distributed computing application approach. :)
#25 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 16,745 posts
Posted Mon Jul 25, 2005 1:53 AM
Not out of my head. But using a big hash map for recognizing repeated patterns plus A* should help.
And the Jammed puzzles where selected (for diversity and compression ratio) out of millions of puzzles generated by a PIII-800 (at my office) running over night. So IMO brute-force for a few hand-generated levels is not completely out of scope.
