I picked up a second 800XL last week to use on a daily basis and found the TV connection to be really poor.
The is a lot of "noise" in the picture and small, short hroizontal black lines.
I found my ancient monitor cable and hooked up to a TV with composite inputs and the picture is great.
I'm assuming the RF modulator is on it's way out.
Are the two video sections tied together and can the RF modulator be repaired other than replaced.
I see B&C sells replacements also.
Ideally, I would like all of this computer to be functioning as it will be moved around and probably hooked up to a TV both ways.
BTW, I'm not using a switch box either. I ised a direct connect using the Atari cable and a coax adapter on the set for the TV antenna test.
Cheers Dave
