UNIXcoffee928 Posted November 5, 2008 Share Posted November 5, 2008 (edited) This thread is for describing methods of accurately reverse-engineering the POKEY, so that it may first be described & documented on a breadboard, and then, may be used to facilitate a model that can be used in a FPGA description language. This idea came to life in the "Atari on a Breadboard" thread, but will be treated as a separate concept, to keep the threads from becoming distracting & cluttered. Here are the links to all related threads in this "Brute Force Initiative": - Atari on a Breadboard - POKEY on a Breadboard - ANTIC on a Breadboard - SALLY on a Breadboard - GTIA on a Breadboard - PIA on a Breadboard - Full Atari Documentation for the POKEY in .pdf format ========================================================= POKEY ========================================================= _________ | | | | | - | 01. Vss -| 01 40 |- 40. D2 02. D3 -| 02 39 |- 39. D1 03. D4 -| 03 38 |- 38. D0 04. D5 -| 04 37 |- 37. AUD 05. D6 -| 05 36 |- 36. A0 06. D7 -| 06 35 |- 35. A1 07. Ø2 -| 07 34 |- 34. A2 08. P6 -| 08 33 |- 33. A3 09. P7 -| 09 32 |- 32. R/W 10. P4 -| 10 31 |- 31. CS1 11. P5 -| 11 30 |- 30. CS0 12. P2 -| 12 29 |- 29. IRQ 13. P3 -| 13 28 |- 28. SOD 14. P0 -| 14 27 |- 27. OCLK 15. P1 -| 15 26 |- 26. BCLK 16. KR2 -| 16 25 |- 25. KR1 17. Vcc *| 17 24 |- 24. SID 18. K5 -| 18 23 |- 23. K0 19. K4 -| 19 22 |- 22. K1 20. K3 -| 20 21 |- 21. K2 |_________| | POKEY | |_________| ========================================================= POKEY (Pins run 0-20 on left & 40-21 on the right) ========================================================= 01. Vss: Ground 02. D3: Memory data bus 3 03. D4: Memory data bus 4 04. D5: Memory data bus 5 05. D6: Memory data bus 6 06. D7: Memory data bus 7 07. Ø2: Phase 2 clock input 08. P6: Paddle input 6 09. P7: Paddle input 7 10. P4: Paddle input 4 11. P5: Paddle input 5 12. P2: Paddle input 2 13. P3: Paddle input 3 14. P0: Paddle input 0 15. P1: Paddle input 1 16. KR2: Keyboard row strobe 17. Vcc: +5V power 18. K5: Keyboard input 5 19. K4: Keyboard input 4 20. K3: Keyboard input 3 21. K2: Keyboard input 2 22. K1: Keyboard input 1 23. K0: Keyboard input 0 24. SID: Serial input data 25. KR1: Keyboard row strobe 26. BCLK: Bidirectional clock 27. OCLK (ACLK in the diagram): Serial output clock 28. SOD: Serial output data 29. IRQ: Interrupt request output to CPU 30. CS0: Chip select 31. CS1: Chip select 32. R/W: Read/write direction 33. A3: Memory addr bus 3 34. A2: Memory addr bus 2 35. A1: Memory addr bus 1 36. A0: Memory addr bus 0 37. AUD: Audio output 38. D0: Memory data bus 0 39. D1: Memory data bus 1 40. D2: Memory data bus 2 Welcome Aboard! Edited November 11, 2008 by UNIXcoffee928 Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 5, 2008 Share Posted November 5, 2008 I thought the schematic for the Pokey chip was released at one point. Mitch Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 5, 2008 Share Posted November 5, 2008 Pokey's behaviour is pretty well known and documented (although not all in the one place). The schematics around for all Atari's ICs seem incomplete and in any case I reckon that rather than a reverse-engineering approach, an "emulation" approach would be better. Quote Link to comment Share on other sites More sharing options...
Bryan Posted November 7, 2008 Share Posted November 7, 2008 http://www.retroclinic.com/leopardcats/bbp...key_project.htm Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 7, 2008 Share Posted November 7, 2008 Nice, but he's only got a subset of Pokey going. Didn't mention either if he's got 16 bit sound going, although I don't imagine it would be a large addition to what's already there. Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted November 11, 2008 Author Share Posted November 11, 2008 (edited) FPGA POKEY Implementation found! While this may be old news to some, here it is. I am not sure how complete it is, but feel free to look at the code, & comment... -- -- A simulation model of Asteroids Deluxe hardware -- Copyright © MikeJ - May 2004 -- -- All rights reserved -- -- Redistribution and use in source and synthezised forms, with or without -- modification, are permitted provided that the following conditions are met: -- -- Redistributions of source code must retain the above copyright notice, -- this list of conditions and the following disclaimer. -- -- Redistributions in synthesized form must reproduce the above copyright -- notice, this list of conditions and the following disclaimer in the -- documentation and/or other materials provided with the distribution. -- -- Neither the name of the author nor the names of other contributors may -- be used to endorse or promote products derived from this software without -- specific prior written permission. -- -- THIS CODE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" -- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, -- THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR -- PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE -- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR -- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF -- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS -- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN -- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) -- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE -- POSSIBILITY OF SUCH DAMAGE. -- -- You are responsible for any legal issues arising from your use of this code. -- -- The latest version of this file can be found at: www.fpgaarcade.com -- -- Email support@fpgaarcade.com -- -- Revision list -- -- version 002 return 00 on allpot when fast scan completed to fix self test -- version 001 initial release (this version should be considered Beta -- it seems to make all the right sort of sounds however ... ) -- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; use work.pkg_asteroids.all; entity ASTEROIDS_POKEY is port ( ADDR : in std_logic_vector(3 downto 0); DIN : in std_logic_vector(7 downto 0); DOUT : out std_logic_vector(7 downto 0); DOUT_OE_L : out std_logic; RW_L : in std_logic; CS : in std_logic; -- used as enable CS_L : in std_logic; -- AUDIO_OUT : out std_logic_vector(7 downto 0); -- PIN : in std_logic_vector(7 downto 0); ENA : in std_logic; CLK : in std_logic -- note 6 Mhz ); end; architecture RTL of ASTEROIDS_POKEY is type array_8x8 is array (0 to 7) of std_logic_vector(7 downto 0); type array_4x8 is array (1 to 4) of std_logic_vector(7 downto 0); type array_4x4 is array (1 to 4) of std_logic_vector(3 downto 0); type array_4x9 is array (1 to 4) of std_logic_vector(8 downto 0); type array_2x17 is array (1 to 2) of std_logic_vector(16 downto 0); type bool_4 is array (1 to 4) of boolean; signal we : std_logic; signal oe : std_logic; -- signal ena_64k_15k : std_logic; signal cnt_64k : std_logic_vector(4 downto 0) := (others => '0'); signal ena_64k : std_logic; signal cnt_15k : std_logic_vector(6 downto 0) := (others => '0'); signal ena_15k : std_logic; -- signal poly4 : std_logic_vector(3 downto 0) := (others => '0'); signal poly5 : std_logic_vector(4 downto 0) := (others => '0'); signal poly9 : std_logic_vector(8 downto 0) := (others => '0'); signal poly17 : std_logic_vector(16 downto 0) := (others => '0'); signal poly_17_9 : std_logic; -- registers signal audf : array_4x8 := (x"00",x"00",x"00",x"00"); signal audc : array_4x8 := (x"00",x"00",x"00",x"00"); signal audctl : std_logic_vector(7 downto 0) := "00000000"; signal stimer : std_logic_vector(7 downto 0); signal skres : std_logic_vector(7 downto 0); signal potgo : std_logic; signal serout : std_logic_vector(7 downto 0); signal irqen : std_logic_vector(7 downto 0); signal skctls : std_logic_vector(7 downto 0); signal reset : std_logic; -- signal kbcode : std_logic_vector(7 downto 0); signal random : std_logic_vector(7 downto 0); signal serin : std_logic_vector(7 downto 0); signal irqst : std_logic_vector(7 downto 0); signal skstat : std_logic_vector(7 downto 0); -- signal pot_fin : std_logic; signal pot_cnt : std_logic_vector(7 downto 0); signal pot_val : array_8x8; signal pin_reg : std_logic_vector(7 downto 0); signal pin_reg_gated : std_logic_vector(7 downto 0); -- signal chan_ena : std_logic_vector(4 downto 1); signal tone_gen_div : std_logic_vector(4 downto 1); signal tone_gen_cnt : array_4x8 := (others => (others => '0')); signal tone_gen_div_mux : std_logic_vector(4 downto 1); signal tone_gen_zero : std_logic_vector(4 downto 1); signal tone_gen_zero_t : array_4x8 := (others => (others => '0')); signal chan_done_load : std_logic_vector(4 downto 1) := (others => '0'); -- signal poly_sel : std_logic_vector(4 downto 1); signal poly_sel_hp : std_logic_vector(4 downto 1); signal poly_sel_hp_t1 : std_logic_vector(4 downto 1); signal poly_sel_hp_reg : std_logic_vector(4 downto 1); signal tone_gen_final : std_logic_vector(4 downto 1) := (others => '0'); begin p_we : process(RW_L, CS_L, CS, ENA) begin we <= (not CS_L) and CS and (not RW_L) and ENA; end process; p_oe : process(RW_L, CS_L, CS) begin oe <= (not CS_L) and CS and RW_L; end process; DOUT_OE_L <= not oe; p_ipreg : process begin wait until rising_edge(CLK); -- in asteroids, these are dip switches pin_reg <= PIN; end process; p_dividers : process begin wait until rising_edge(CLK); if (ENA = '1') then ena_64k <= '0'; if cnt_64k = "00000" then cnt_64k <= "11011"; -- 28 - 1 ena_64k <= '1'; else cnt_64k <= cnt_64k - "1"; end if; ena_15k <= '0'; if cnt_15k = "0000000" then cnt_15k <= "1110001"; -- 114 - 1 ena_15k <= '1'; else cnt_15k <= cnt_15k - "1"; end if; end if; end process; p_ena_64k_15k : process(ena_64k, ena_15k, audctl) begin if (audctl(0) = '1') then ena_64k_15k <= ena_15k; else ena_64k_15k <= ena_64k; end if; end process; p_poly : process variable poly9_zero : std_logic; variable poly17_zero : std_logic; begin wait until rising_edge(CLK); if (ENA = '1') then poly4 <= poly4(2 downto 0) & not (poly4(3) xor poly4(2)); poly5 <= poly5(3 downto 0) & not (poly5(4) xor poly4(2)); -- used inverted -- not correct poly9_zero := '0'; if (poly9 = "000000000") then poly9_zero := '1'; end if; poly9 <= poly9(7 downto 0) & (poly9( xor poly9(3) xor poly9_zero); poly17_zero := '0'; if (poly17 = "00000000000000000") then poly17_zero := '1'; end if; poly17 <= poly17(15 downto 0) & (poly17(16) xor poly17(2) xor poly17_zero); end if; end process; p_random_mux : process(audctl, poly9, poly17) begin -- bit unnecessary this .... for i in 0 to 7 loop if (audctl(7) = '1') then -- 9 bit poly random(i) <= poly9(8-i); else random(i) <= poly17(16-i); end if; end loop; if (audctl(7) = '1') then poly_17_9 <= poly9(; else poly_17_9 <= poly17(16); end if; end process; p_wdata : process begin wait until rising_edge(CLK); potgo <= '0'; --if (reset = '1') then -- no idea what the reset state is --audf <= (others => (others => '0')); --audc <= (others => (others => '0')); --audctl <= x"00"; --else if (we = '1') then case ADDR is when x"0" => audf(1) <= DIN; when x"1" => audc(1) <= DIN; when x"2" => audf(2) <= DIN; when x"3" => audc(2) <= DIN; when x"4" => audf(3) <= DIN; when x"5" => audc(3) <= DIN; when x"6" => audf(4) <= DIN; when x"7" => audc(4) <= DIN; when x"8" => audctl <= DIN; when x"9" => stimer <= DIN; when x"A" => skres <= DIN; when x"B" => potgo <= '1'; --when x"C" => when x"D" => serout <= DIN; when x"E" => irqen <= DIN; when x"F" => skctls <= DIN; when others => null; end case; end if; --end if; end process; p_reset : process(skctls) begin -- chip in reset if bits 1..0 of skctls are both zero reset <= '0'; if (skctls(1 downto 0) = "00") then reset <= '1'; end if; end process; p_rdata : process(oe, ADDR, pot_val, pin_reg_gated, kbcode, random, serin, irqst, skstat) begin DOUT <= x"00"; if (oe = '1') then -- keep things quiet case ADDR IS when x"0" => DOUT <= pot_val(0); -- pot 0 when x"1" => DOUT <= pot_val(1); -- pot 1 when x"2" => DOUT <= pot_val(2); -- pot 2 when x"3" => DOUT <= pot_val(3); -- pot 3 when x"4" => DOUT <= pot_val(4); -- pot 4 when x"5" => DOUT <= pot_val(5); -- pot 5 when x"6" => DOUT <= pot_val(6); -- pot 6 when x"7" => DOUT <= pot_val(7); -- pot 7 when x"8" => DOUT <= pin_reg_gated;-- allpot when x"9" => DOUT <= kbcode; when x"A" => DOUT <= random; when x"B" => DOUT <= x"FF"; when x"C" => DOUT <= x"FF"; when x"D" => DOUT <= serin; when x"E" => DOUT <= irqst; when x"F" => DOUT <= skstat; when others => null; end case; end if; end process; -- POT ANALOGUE IN UNTESTED !! p_pot_cnt : process begin wait until rising_edge(CLK); if (potgo = '1') then pot_cnt <= x"00"; elsif ((ena_15k = '1') or (skctls(2) = '1')) and (ENA = '1') then -- fast scan mode pot_cnt <= pot_cnt + "1"; end if; end process; p_pot_comp : process begin wait until rising_edge(CLK); if (reset = '1') then pot_fin <= '1'; else if (potgo = '1') then pot_fin <= '0'; elsif (pot_cnt = x"E4") then -- 228 pot_fin <= '1'; end if; end if; end process; p_pot_val : process begin wait until rising_edge(CLK); for i in 0 to 7 loop if (pot_fin = '0') and (pin_reg(i) = '0') then -- continue latching counter value until input reaches ViH threshold pot_val(i) <= pot_cnt; end if; end loop; end process; -- dump transistors --PIN <= x"00" when (pot_fin = '1') else (others => 'Z'); p_in_gate : process(pin_reg, reset) -- dump transistor fakeup begin pin_reg_gated <= pin_reg; -- I think the datasheet lies about dump transistors being disabled -- in fast scan mode, as the self test fails .... if (reset = '1') or (pot_fin = '1') then --and (skctls(2) = '0')) pin_reg_gated <= x"00"; end if; end process; p_tone_cnt_ena : process(audctl, ena_64k_15k, tone_gen_div) variable chan_ena1, chan_ena3 : std_ulogic; begin if (audctl(6) = '1') then chan_ena1 := '1'; -- 1.5 MHz, else chan_ena1 := ena_64k_15k; end if; chan_ena(1) <= chan_ena1; if (audctl(4) = '1') then -- chan 1/2 joined chan_ena(2) <= chan_ena1; else chan_ena(2) <= ena_64k_15k; end if; if (audctl(5) = '1') then chan_ena3 := '1'; -- 1.5 MHz, else chan_ena3 := ena_64k_15k; -- 64 KHz end if; chan_ena(3) <= chan_ena3; if (audctl(3) = '1') then -- chan 3/4 joined chan_ena(4) <= chan_ena3; else chan_ena(4) <= ena_64k_15k; -- 64 KHz end if; end process; p_tone_generator_zero : process(tone_gen_cnt, chan_ena) begin for i in 1 to 4 loop if (tone_gen_cnt(i) = "00000000") and (chan_ena(i) = '1') then tone_gen_zero(i) <= '1'; else tone_gen_zero(i) <= '0'; end if; end loop; end process; p_tone_generators : process variable chan_load : std_logic_vector(4 downto 1); variable chan_dec : std_logic_vector(4 downto 1); begin -- quite tricky this .. but I think it does the correct stuff -- bet this is not how is was done originally ! -- -- nasty frig to easily get exact chip behaviour in high speed mode -- fout = fin / 2(audf + n) when n=4 or 7 in 16 bit mode wait until rising_edge(CLK); if (ENA = '1') then tone_gen_div <= "0000"; if (audctl(4) = '1') then -- chan 1/2 joined chan_load(1) := '0'; chan_load(2) := '0'; if (tone_gen_zero_t(1)(5) = '1') and (tone_gen_zero_t(2)(5) = '1') and (chan_done_load(1) = '0') then chan_load(1) := '1'; chan_load(2) := '1'; end if; chan_dec(1) := '1'; chan_dec(2) := tone_gen_zero(1); else chan_load(1) := tone_gen_zero_t(1)(2) and not chan_done_load(1); chan_load(2) := tone_gen_zero_t(2)(2) and not chan_done_load(2); chan_dec(1) := '1'; chan_dec(2) := '1'; end if; if (audctl(3) = '1') then -- chan 1/2 joined chan_load(3) := '0'; chan_load(4) := '0'; if (tone_gen_zero_t(3)(5) = '1') and (tone_gen_zero_t(4)(5) = '1') and (chan_done_load(3) = '0') then chan_load(3) := '1'; chan_load(4) := '1'; end if; chan_dec(3) := '1'; chan_dec(4) := tone_gen_zero(3); else chan_load(3) := tone_gen_zero_t(3)(2) and not chan_done_load(3); chan_load(4) := tone_gen_zero_t(4)(2) and not chan_done_load(4); chan_dec(3) := '1'; chan_dec(4) := '1'; end if; for i in 1 to 4 loop if (chan_load(i) = '1') then chan_done_load(i) <= '1'; tone_gen_div(i) <= '1'; tone_gen_cnt(i) <= audf(i); elsif (chan_dec(i) = '1') and (chan_ena(i) = '1') then chan_done_load(i) <= '0'; tone_gen_cnt(i) <= tone_gen_cnt(i) - "1"; end if; tone_gen_div(i) <= chan_load(i); tone_gen_zero_t(i)(7 downto 0) <= tone_gen_zero_t(i)(6 downto 0) & tone_gen_zero(i); end loop; end if; end process; p_tone_generator_mux : process(audctl, tone_gen_div) begin if (audctl(4) = '1') then -- chan 1/2 joined tone_gen_div_mux(1) <= tone_gen_div(1); -- do they both waggle tone_gen_div_mux(2) <= tone_gen_div(2); -- or do I mute chan 1? else tone_gen_div_mux(1) <= tone_gen_div(1); tone_gen_div_mux(2) <= tone_gen_div(2); end if; if (audctl(3) = '1') then -- chan 3/4 joined tone_gen_div_mux(3) <= tone_gen_div(3); -- ditto tone_gen_div_mux(4) <= tone_gen_div(4); else tone_gen_div_mux(3) <= tone_gen_div(3); tone_gen_div_mux(4) <= tone_gen_div(4); end if; end process; p_poly_gating : process(audc, poly4, poly5, poly_17_9, tone_gen_div_mux) variable filter_a : std_logic_vector(4 downto 1); variable filter_b : std_logic_vector(4 downto 1); begin for i in 1 to 4 loop if (audc(i)(7) = '0') then filter_a(i) := poly5(4) and tone_gen_div_mux(i);-- 5 bit poly else filter_a(i) := tone_gen_div_mux(i); end if; if (audc(i)(6) = '0') then filter_b(i) := poly_17_9 and filter_a(i);-- 17 bit poly else filter_b(i) := poly4(3) and filter_a(i);-- 4 bit poly end if; if (audc(i)(5) = '0') then poly_sel(i) <= filter_b(i); else poly_sel(i) <= filter_a(i); end if; end loop; end process; p_high_pass_filters : process(audctl, poly_sel, poly_sel_hp_reg) begin poly_sel_hp <= poly_sel; if (audctl(2) = '1') then poly_sel_hp(1) <= poly_sel(1) xor poly_sel_hp_reg(1); end if; if (audctl(1) = '1') then poly_sel_hp(2) <= poly_sel(2) xor poly_sel_hp_reg(2); end if; end process; p_audio_out : process begin wait until rising_edge(CLK); if (ENA = '1') then for i in 1 to 4 loop -- filter reg if (tone_gen_div(3) = '1') then -- tone gen 1 clocked by gen 3 poly_sel_hp_reg(1) <= poly_sel(1); end if; if (tone_gen_div(4) = '1') then -- tone gen 2 clocked by gen 4 poly_sel_hp_reg(2) <= poly_sel(2); end if; poly_sel_hp_t1 <= poly_sel_hp; if (poly_sel_hp(i) = '1') and (poly_sel_hp_t1(i) = '0') then -- rising edge tone_gen_final(i) <= not tone_gen_final(i); end if; end loop; end if; end process; p_op_mixer : process variable vol : array_4x4; variable sum12 : std_logic_vector(4 downto 0); variable sum34 : std_logic_vector(4 downto 0); variable sum : std_logic_vector(5 downto 0); begin wait until rising_edge(CLK); if (ENA = '1') then for i in 1 to 4 loop if (audc(i)(4) = '1') then -- vol only vol(i) := audc(i)(3 downto 0); else if (tone_gen_final(i) = '1') then vol(i) := audc(i)(3 downto 0); else vol(i) := "0000"; end if; end if; end loop; sum12 := ('0' & vol(1)) + ('0' & vol(2)); sum34 := ('0' & vol(3)) + ('0' & vol(4)); sum := ('0' & sum12) + ('0' & sum34); if (reset = '1') then AUDIO_OUT <= "00000000"; else if (sum(5) = '0') then AUDIO_OUT <= sum(4 downto 0) & "000"; else -- clip AUDIO_OUT <= "11111111"; end if; end if; end if; end process; -- keyboard / serial etc to do end architecture RTL; At first glance, it appears to be missing Reset, Keyboard operations, and Serial operations, but should be a good starting point for a full implementation. Edited November 11, 2008 by UNIXcoffee928 Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 11, 2008 Share Posted November 11, 2008 Pokey doesn't have a Reset pin - that's what the SKCTL "00" Init state is for. Keyboard scan is reasonably well documented. If you were to build a reengineered Atari, you'd probably want to use a PS2 or USB keyboard anyway - translation to the Pokey mode of operation could be emulated. Serial - not so sure that's totally straightforward. Analog Multiplexor has lots of info - I think there might be extra trickery like bit transitions resetting serial timers (voices). Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted November 11, 2008 Author Share Posted November 11, 2008 (edited) Pokey doesn't have a Reset pin - that's what the SKCTL "00" Init state is for. Yes, & that is in there. I should have been more clear, I meant this code chunk in p_wdata : process: --if (reset = '1') then -- no idea what the reset state is --audf <= (others => (others => '0')); --audc <= (others => (others => '0')); --audctl <= x"00"; --else Edited November 11, 2008 by UNIXcoffee928 Quote Link to comment Share on other sites More sharing options...
+David_P Posted January 3, 2009 Share Posted January 3, 2009 Pokey doesn't have a Reset pin - that's what the SKCTL "00" Init state is for. Keyboard scan is reasonably well documented. If you were to build a reengineered Atari, you'd probably want to use a PS2 or USB keyboard anyway - translation to the Pokey mode of operation could be emulated. Serial - not so sure that's totally straightforward. Analog Multiplexor has lots of info - I think there might be extra trickery like bit transitions resetting serial timers (voices). For those interested in a PS2 interface, look at http://sbc.rictor.org/io/pckbavr.html ; it's an ATTiny26-based PS2 keyboard interface. While designed for a parallel port, with a little work it could be adapted to POKEY. Quote Link to comment Share on other sites More sharing options...
sl0re Posted January 22, 2009 Share Posted January 22, 2009 Ok, how about this one? http://www.retromicro.com/files/atari/8bit/pokey.pdf Link given to me by Phaeron Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 22, 2009 Share Posted January 22, 2009 Nice and compact. Something like that would be a sellable upgrade... as is I have my machine sitting on a little table off to the side. Being able to just use the one keyboard via KVM switch would make Atari life a good deal easier. Quote Link to comment Share on other sites More sharing options...
+David_P Posted January 22, 2009 Share Posted January 22, 2009 Nice and compact. Something like that would be a sellable upgrade... as is I have my machine sitting on a little table off to the side. Being able to just use the one keyboard via KVM switch would make Atari life a good deal easier. There's also a Gumby stereo upgrade that includes a PS2 interface - see http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...em=330300131963 for a bit more information. Mine is enroute... Quote Link to comment Share on other sites More sharing options...
Math You Posted January 22, 2009 Share Posted January 22, 2009 Didn't mention either if he's got 16 bit sound goingI was reading about how the pokey chip could produce 16 bit sound on Wikipedia but thought it must have been a mistake, is it true? Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 22, 2009 Share Posted January 22, 2009 When we say "16 bit sound", it just means 16 bits representing the frequency rather than 8, by joining 2 voices together. Quote Link to comment Share on other sites More sharing options...
Math You Posted January 22, 2009 Share Posted January 22, 2009 When we say "16 bit sound", it just means 16 bits representing the frequency rather than 8, by joining 2 voices together.So there's no 16bit control over the volume control, as in 16bit sampled sound? Quote Link to comment Share on other sites More sharing options...
viande Posted October 17, 2009 Share Posted October 17, 2009 (edited) Hi If thats any help, ive independently analysed the 4/5/9/17 bit polys from the POKEY using a breadboard as an retentive attempt to do it myself for chipsounds. Its important to know that the goal of chipsounds is not to make a better machine emulator but a better representation of a MIDI driven pokey uniquely. here are my notes: http://ploguechipsounds.blogspot.com/2009/10/how-i-recorded-and-decoded-pokeys.html Old trials: http://ploguechipsounds.blogspot.com/2009/03/pokey-trials.html Edited October 17, 2009 by viande Quote Link to comment Share on other sites More sharing options...
