UNIXcoffee928 Posted November 5, 2008 Share Posted November 5, 2008 (edited) This thread is for describing methods of accurately reverse-engineering the PIA, so that it may first be described & documented on a breadboard, and then, may be used to facilitate a model that can be used in a FPGA description language. This idea came to life in the "Atari on a Breadboard" thread, but will be treated as a separate concept, to keep the threads from becoming distracting & cluttered. Here are the links to all related threads in this "Brute Force Initiative": - Atari on a Breadboard - POKEY on a Breadboard - ANTIC on a Breadboard - SALLY on a Breadboard - GTIA on a Breadboard - PIA on a Breadboard ========================================================= PIA ========================================================= _________ | | | | | - | 01. Vss -| 01 40 |- 40. CA1 02. PA0 -| 02 39 |- 39. CA2 03. PA1 -| 03 38 |- 38. IRQA 04. PA2 -| 04 37 |- 37. IRQB 05. PA3 -| 05 36 |- 36. A1 06. PA4 -| 06 35 |- 35. A0 07. PA5 -| 07 34 |- 34. RST 08. PA6 -| 08 33 |- 33. D0 09. PA7 -| 09 32 |- 32. D1 10. PB0 -| 10 31 |- 31. D2 11. PB1 -| 11 30 |- 30. D3 12. PB2 -| 12 29 |- 29. D4 13. PB3 -| 13 28 |- 28. D5 14. PB4 -| 14 27 |- 27. D6 15. PB5 -| 15 26 |- 26. D7 16. PB6 -| 16 25 |- 25. Ø2 17. PB7 -| 17 24 |- 24. CS1 18. CB1 -| 18 23 |- 23. CS2 19. CB2 -| 19 22 |- 22. CS0 20. Vcc -| 20 21 |- 21. R/W |_________| | PIA | |_________| ========================================================= PIA (Pins run 0-20 on left & 40-21 on the right) ========================================================= 01. Vss: Ground 02. PA0: Bidirectional port A 0 (stick direction, paddle triggers, etc.) 03. PA1: Bidirectional port A 1 (stick direction, paddle triggers, etc.) 04. PA2: Bidirectional port A 2 (stick direction, paddle triggers, etc.) 05. PA3: Bidirectional port A 3 (stick direction, paddle triggers, etc.) 06. PA4: Bidirectional port A 4 (stick direction, paddle triggers, etc.) 07. PA5: Bidirectional port A 5 (stick direction, paddle triggers, etc.) 08. PA6: Bidirectional port A 6 (stick direction, paddle triggers, etc.) 09. PA7: Bidirectional port A 7 (stick direction, paddle triggers, etc.) 10. PB0: Bidirectional port B 0 (stick direction, paddle triggers, etc.) 11. PB1: Bidirectional port B 1 (stick direction, paddle triggers, etc.) 12. PB2: Bidirectional port B 2 (stick direction, paddle triggers, etc.) 13. PB3: Bidirectional port B 3 (stick direction, paddle triggers, etc.) 14. PB4: Bidirectional port B 4 (stick direction, paddle triggers, etc.) 15. PB5: Bidirectional port B 5 (stick direction, paddle triggers, etc.) 16. PB6: Bidirectional port B 6 (stick direction, paddle triggers, etc.) 17. PB7: Bidirectional port B 7 (stick direction, paddle triggers, etc.) 18. CB1: Port B control 19. CB2: Port B control 20. Vcc: +5V power 21. R/W: Read/write direction 22. CS0: Chip Select 23. CS2: Chip Select (active low) 24. CS1: Chip Select 25. Ø2: Sync 26. D7: Data bus 7 27. D6: Data bus 6 28. D5: Data bus 5 29. D4: Data bus 4 30. D3: Data bus 3 31. D2: Data bus 2 32. D1: Data bus 1 33. D0: Data bus 0 34. RST: Chip reset 35. A0: Addr bus 0 36. A1: Addr bus 1 37. IRQB: Port B interrupt line 38. IRQA: Port A interrupt lines 39. CA2: Port A control 40. CA1: Port A control Welcome Aboard! Edited November 5, 2008 by UNIXcoffee928 Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 5, 2008 Share Posted November 5, 2008 PIA workalikes are still alive and available today. Probably not worth trying to duplicate the functions of something available off the shelf for a few bucks. Quote Link to comment Share on other sites More sharing options...
